rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have not seen PB pipe used only for the main supply before, especially not going into the ground. It only comes in from the meter about 25 feet under the house, then connects to copper distribution.
Does the larger pb have the same issues? I don't see why it wouldn't, but at least there is less of it and only a couple of fittings. ![]()
Hi Ralph,
I have never seen a PB main either, but that is what you have, I would right it up as a potential issue both due to the fittings issue (not too much of a problem with that system) but also because Chlorinated water leaches out the plastic from the inside leaving the piping very brittle. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Come to AZ.... Many a side walk / driveway has been dug up and repaired here from the meter to the main and we know it was poly before.
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Pretty common here also. Just inspected a townhouse that was plumbed this way. So I can assume several hundred others in the development are as well.
PB main water service is very common in the areas that I cover. Yes, the blue PB pipe has the same problems as other gray PB pipe typically found in interior plumbing.
I have inspected some homes where the blue pipe is not visible, the only indicator is the gray 90 degree plastic elbow connected to the internal copper pipe at the foundation wall. |
| Neutral bus bar failed inspection | Greg Moritz | Electrical Inspections | 18 | 1/19/08 2:53 PM |
| Main supply "T's" off to 2nd floor | Mark Ellison | Plumbing Inspections | 3 | 4/25/06 9:00 PM |
