| View Poll Results: Is Polybutylene Piping a Defect | |||
| Yes |
24 | 64.86% |
| No |
6 | 16.22% |
| What is Polybutylene Piping? |
1 | 2.70% |
| It is Obama's Fault |
6 | 16.22% |
| Voters: 37. You may not vote on this poll | |||
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Defect:
1 a : an imperfection that impairs worth or utility PB systems come in many varieties, here are some of the most common combinations I see: (Note: there are some PB pipes that are not the 2110 version that was not involved in the lawsuit but they are rarely found) PB2110 pipe with plastic fittings on public water system - the absolute worst, most of these have flooded houses and been improved or replaced. PB2110 pipe with plastic fittings on private water system - still very bad PB2110 pipe with copper fittings and copper crimp rings on public water - the copper fittings were also part of the lawsuit and the public water will deteriorate the pipe. - still very bad. PB2110 pipe with copper fittings and copper crimp rings on well water water - the copper fittings were also part of the lawsuit - still bad. Here is a system that may exist somewhere but I have not seen it yet: PB2110 pipe with new brass fittings and copper crimp rings on well water - This exact setup might be better but you will still get sued if it floods the house and you did not make the client aware of the issues with PB. Don't forget to check the service pipe from the street also to see if its PB. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 5/27/10 at 10:03 PM.. |
You know it isn't---
Hasn't popped in "You know who's house yet"----- Bet you wish it would though---- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
You realise the guys that voted no are wrong, right?
Hey..it's only 26%...what do you want?---
I voted O-blame-a---- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
How do you check from the meter to the house?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
So we have 5 posters who have PB in their own house
Or even worse, they believe the agents that tell them not to report it because "other inspectors don't". B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 5/29/10 at 1:35 PM.. |
The service pipe is usually visible at the shut off valve area. Some slab houses have PB visible under the stairs and behind the water heater or in the garage/utility room. Crawl houses are usually visible at the front of the crawlspace or near the crawl door. Sometimes its visible at the water meter but usually covered up with dirt. If you see PB for distribution you should report that the service line needs to be checked also. The service pipes seemed to leak even worse and many have been replaced already.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Pretty hard to do here Mark.
In my last Neighborhood all the Houses had PB plumbing, both inside and outside... For the most part everyone in the Neighborhood did not make it to 10 yrs before the Outside PB piping failed. No leaks on the inside that I was aware of... |
I use this as an advisory comment on homes that have PB:
Polybutylene pipe supply lines present. This type pipe has a history of failures and has been involved in a class action law suit. No problems were found during the inspection. Homeowners with polybutylene can register with the Consumer Plumbing Recovery Center to become eligible to file a claim should failures occur. For complete information on the class action and settlement, call 1-800-392-7591 or to visit www.pbpipe.com. Priority Home Inspections has teamed up with the Dish Network to give you a FREE Dish Network system. Log onto www.Free-Dish-For-You.com for all the details. Priority Home Inspections, Inc. 321-368-9921 www.BrevardHomeInspector.com www.AvoidAMoneyPit.com www.BrevardInsuranceSavings.com www.BrevardBuildersWarranty.com www.PrioritySignPosts.com Info@BrevardHomeInspector.com |
After looking at the link myself, homeowners can no longer file a claim as of May 2009. Time to update my phrases. I think the homeowner should no that they have polybutylene supply lines, even if there are no problems found during the inspection.
Polybutylene pipe supply lines present. This type pipe has a history of failures and has been involved in a class action law suit. No problems were found during the inspection. Additional anecdotal data is available on the world wide web by searching "Polybutylene Pipe". Priority Home Inspections has teamed up with the Dish Network to give you a FREE Dish Network system. Log onto www.Free-Dish-For-You.com for all the details. Priority Home Inspections, Inc. 321-368-9921 www.BrevardHomeInspector.com www.AvoidAMoneyPit.com www.BrevardInsuranceSavings.com www.BrevardBuildersWarranty.com www.PrioritySignPosts.com Info@BrevardHomeInspector.com |
Greg Bell Titusville, Fl 02111507 Serving Central Florida
Pb piping is illegal in Chicago and surounding ILLINOIS suburbs. So yes it would be a defect in my area. Your area might be differnt.
Jim Kolke www.chicagohomeinspection.biz www.pinnaclepropertyinspection.com www.aurorahomeinspection.info www.chicagocondoinspection.info www.chicagoinfraredhomeinspection.com www.wilmettehomwinspection.com www.skokiehomeinspection.com www.barringtonhomeinspection.com www.lagrangehomeinspection.com www.oakbrookhomeinspection.com www.napervillehomeinspection.info |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Bonding both hot and hold supply pipes | kshepard | Plumbing Inspections | 22 | 5/4/08 8:00 AM |
| Bonding Piping 101....Good To Know ! | pabernathy | Electrical Inspections | 37 | 4/28/07 11:25 AM |
