Feel free to use this as what not to do.
Jay Schwartz Coast To Coast Home Services, Inc Your Florida Home Inspection Company TM Corporate Office: 954-673-3479 Naples Office: 239-298-4396 1-877-79-Windstorm www.CoastToCoastHomeServices.com www.SaveOnWindStorm.com South Florida Home Inspectors Association Southeast Florida NACHI Chapter - VP |
It looks like that were on the right track in keeping the water heater from freezing. But in Florida who knows why
Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
Jay
Did you win the election?? rlb |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
If it is indeed a supply, then its to blow the CO away from the flue. Lots of headaches/flu like symptoms for the previous owners? |
Ha
Either way it sucks (get it) You could also say the contractor blows. |
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is there a problem having a supply air register on the plenum in Florida?
Oh, I see, the t-p safety valve drain is going uphill. Last edited by sparksnmore; 4/21/08 at 9:26 PM.. |
Sparky, the flue has carbon Monoxide.
Look at the picture. If it is a vent for return or supply you are still in trouble. |
Properly burning gas appliances do not produce Carbon Monoxide, automobiles do.
I agree the supply air register is pretty close to the water heater draft hood but it wont hurt anything to blow a little air past it. |
I hope you are joking.
cfuoco is a non-member guest and is in no way affiliated with InterNACHI or its members.
The trim plate on the pipe going through the wall is a nice touch.
The main point of our fall furnace checks/tune ups is to check the Carbon Monoxide content within the exhaust flue and most all gas furnaces and gas water heaters are only around 3-4 PPM. |
And if the CO doesn't go in the flue (where you check the level) and is allowed to accumulate in the house, what would the result be? |
Sparky, are you a home Inspector?
I hope not. If you are a plumber , all your clients are dead buy now.
| Another deck Collapse | rcooke | Canadian Inspectors | 11 | 3/30/08 9:03 AM |
