tflaro is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am thinking about buying a pipeline camera and I am asking for any info others may have.
Thanx, Todd |
I have a Spartan (150 capability) that I offer at all inspections. Few people want to have it used. Has killed a few and won a few sales. If you use them to do local town lines make sure you get E&O ins. I only do residential.
How much did it cost and what do you charge to do it?
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
I would steer clear of that unless I was a licensed plumber. Ask a plumber and he will most likely tell you that the best way to test for sanitary line leaks is to perform a hydrostatic test.
John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
I would think it is kinda like those that told me Suretests are exceeding the SOP and I should not teach about them. Same could go for Thermal Imaging as well.....anything that exceeds the visual is subject to this verbage.
Personally i am all for technology..... I say bring on the Thermals, the camera's and more testing devices..... Paul W. Abernathy |
I bought mine used for $5000 and I charge $60/hr. usually finish in 1 hr. but you'd be suprised as to what you can find. Even chased a frog though the line once. That job turned into a $1500 job.
1 other guy around here "Septic cleaning co." charges $120/hr for res. But he has all the towns locked up at $175/hr. I always wanted 1 so I bought it. "Boy's and their toys"
I sure would like one of those toys though. I would have to sell a horse to do it. I hate that. </IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Camera’s are a great asset to a plumber. One thing to remember if you are thinking about getting one is that sometimes access is not an easy thing. Sometimes there is no access and one has to be cut in. Other times the brass or cast iron plug has to be cut out it the fire trick does not work.
My area has a tremendous amount of slab foundations with the A/C ducts embedded. A camera can be very useful as these ducts have been known to collapse, get water in them, fill up with sand you name it can happen. I live near a oil refinery the smell is terrible but the money is great folks moving in and out on a regular basis. The re-lo company pays for the inspection and it does not matter to what the extent or price is charged for an inspection within reason. They are mainly concerned that they don't have to place a home in their inventory that has extreme problems. If I was offering a scope check on the ducts would more than likely more than pay for a camera. Just have not purchased one yet procrastination. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Depending on the main trunk size, you may not be able to push the camera though very far. Anything over 10" and the camera may just turn around 10' down the line. Going down each register should not be a problem though.
Jan Lombard is a non-member guest and is in no way affiliated with InterNACHI or its members.
CCTV camera - One the island I live most homes have their own individual septic tanks - one company would do the cleaning, meaning the pump out of the tank. Another company does the camera inspection of the leach field, or drain pipes or whatever you want to call those pipes.
The camera inspection typicaly charges a flat $350 (it evens out those jobs that require more work and others - it also markets better as flat fee - much better than a little more to budget than a depends on.blah blah ...open your purse wider feeling))- in most cases he is not longer than an hour on the job - you also need more than just the camera - also need sensor to pick up above gound where the camera enters the distribution box - else you will be digging up half the back lawn to find the distribution box -this guy is busy and dont just do one a day ! i also want to get this equipment - but I'm not a plumber nor do I have the 'masters degree' of courses required to say the obvious to the client. redhawkreports@yahoo.com |
| Infared cameras | rchorey | General Inspection Discussion | 36 | 9/24/07 5:55 PM |
| What batteries do you use in cameras? | wwarner | General Inspection Discussion | 18 | 2/6/07 10:28 AM |
| Flir B-Cam vs. B2 vs. Fluke Ti20 vs. Ti30 Thermal Imaging Cameras | Dave Downing | General Inspection Discussion | 5 | 2/2/07 9:45 PM |
