Hey Guys-
Anybody seen this kind of connector on a copper line before? Approved, not approved? It looks like an old version of the shark bite connectors. Thanks. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
That is an older pressure fit design. This should be considered temporary but I would not be concerned with it as no problems seem to exist. I would recommend it be changed to shark bite or other grip fitting if slow leak developes.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
PVC Compression Pressure Fittings
These are for joining schedule 40, schedule 80 plastic, iron, steel, and copper pipe to each other. They are leakproof, with no threading or cementing required. Since the cap and body are recessed for a compression sealing gasket, no fluid can enter the thread cavity of the cap, providing a duplex seal. The compressive action creates a strong gripping action over a wide area of pipe resisting longitudinal pull out. Repairs or alterations in pipelines are simple. Couplings can be inserted quickly between butted pipe ends. No clearance room is needed, just slip a coupling all the way over one pipe end, realign the ends, center the coupling, and tighten nuts. It is manufactured from white PVC. The wall thicknesses meet or exceed those of schedule 40 fittings as listed in ASTM D-2466. Features styrene butediene rubber gaskets. NSF listed. ![]() http://www.usplastic.com/catalog/ite...4124&catid=726 The one in your picture appears to be a union compression pressure fitting. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
They may be approved but not for locations inside walls or inaccessible areas. Your picture does not display this.
Commen sense would apply to any mechanical component here other than this one.
Soldered, welded pipe, or continuous piping should always be used where unacessible in building construction. Same applies to gas piping, water piping, such as hydronic piping in concrete slabs for radiant heating systems. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Here is the new style replacement design that matches this style.
http://flosource.com/products/instru...tube-fittings/ I have not seen shark bite yet in Home Inspections here. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I am concerned that there is no Ground Carried through the system when a plastic coupling is used on Copper pipes .
In Canada the Gas equipment is usually Bonded to the copper Water Piping ... Roy |
Good point Roy!
You are correct Roy, but this could just be a homeowner fix and the grounding to the water lines is most likely below the water meter near the shutoff.
I doubt a fitting like this would be acceptable for a gas line. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The Steel gas lines are usuall bonded at the equipment to the copper water line . If the water line had a plastic fitting then it would not be any good to bond too. |
This is not a gas line but a solid cold water line as the picture displays a shut off valve for humidfier. Since it is the cold line it most likely is bonded to the gas line and should be grounded to main water line no more than 5 feet from entrance to the home according to electrical standards here.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 12/27/11 at 9:46 PM.. |
Thanks for the info guys. I didn't think about the bonding problems that this type of fitting could cause. Yes, it was the cold water line.
I'm beginning to see a lot of shark bites around here. The contractor supply stores are now carrying them and a lot of the plumbers are even starting to use them. Rigler Home Inspections Hays, KS 67601 785-656-0272 |
John what made you talk about Bonding between hot and cold ????????.. Roy
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Is this allowed? | belliott | Plumbing Inspections | 4 | 7/15/09 6:40 PM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
