Just saw this on a condo built in 1981. What material is it?
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
The white pipe is PEX. The grey fittings are polybutylene fittings. The PEX is probably recent. (I bet PB is the predominant plumbing material in use.) Any PB would be grounds for referral to a plumber. The mix of materials is reason enough for referral to a plumber.
I can't be sure from the pic but it looks like painted copper stubs coming out of the wall.
The PB fittings are being used as a transition between the copper and the PEX to the water heater. Also, I think the TPR has PVC attached and that would be the wrong material for this use. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I think with all the copper being stolen, they came up with this product for replacement. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Thanks Mark. I haven't seen that yet.
I would think CPVC would be the easiest replacement choice. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I appears to be leaking at the copper / CPVC connections...
Attached is a set up of last week with the addition of a few other material. Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Andrew - PEX is not allowed for the first 18" of the water-heater supply or return. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
It looks just like PVC though, and it would be easy to glance at and make a bad call. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
For The Record: PEX is allowed for the first 18" of *electric* water-heater supply or return in Canada, go figure...
Some info on the pipe markings on the pipe visible in the picture.
COVERAGE:
CSA Standard B137.3Rigid Poly (Vinyl Chloride) (PVC) Pipe for Pressure ApplicationsCSA Standard B137.6CPVC Pipe, Tubing and Fittings for Hot and Cold Water Distribution SystemsCSA Standard B137.2PVC Injection - Moulded Gasketed Fittings for Pressure Applications. The above Standards may also require the use of associated Bulletins, Notices and/or Supplements due, for example, to new requirements becoming effective after publication of the Standards. MARKING: All marking required by CSA must be permanent, legible, and visible after manufacture of the pipe. The contents consist of:
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I didn't check the IRC or Canadian requirements.
That's great if you're in Canada Marcel.
Mike, I am just showing the info found for the markings on the pipe.
I am not saying it is right. That whole messs should be redone by a licensed Plumber, point blank. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Sorry Marcel, I didn't mean to offend.
IMHO the NSF marking is more relevant. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
No offense taken Mike and why do you day NSF is more relevant? It's all part of the identification markings on the pipe.
No matter what I punch in for information, leads me to the same place. The pipe came from Canada I guess. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Is this allowed? | belliott | Plumbing Inspections | 4 | 7/15/09 6:40 PM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
