Old 6/24/11, 1:23 PM
Mark E. Glowczynski's Avatar
Mark E. Glowczynski Mark E. Glowczynski is offline
Send a message via ICQ to mglowczynski
Default Plastic pipe
Found this during an inspection yesterday. It does not look like PB, but rather piping for campers and rv's and such. Sorry for the picture not being close enough to see what was stamped on it. Whatever it is, it was only secured at the connection to copper supply and at the faucet. Any help would be great, report due tomorrow night.plastic-pipe-dsc05847.jpgplastic-pipe-dsc05846.jpgplastic-pipe-dsc05849.jpg
Mark Glowczynski
Right at Home Inspections & Solutions
708 473 5116
Residential Commercial Pre Listing Foreclosures New Construction
Condo Annual Inspections
Illinois Licensed
Proud Member of InterNACHI
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/24/11, 1:40 PM
Jeffrey R. Jonas's Avatar
Default Re: Plastic pipe
Thinwall PVC. Many hardware stores carry it. Need the marking off of it to verify. Most AHJ's do not allow it. Unsure what 'code' says about it.
Old 6/24/11, 9:17 PM
pcooley pcooley is offline
Please Note: pcooley is a non-member guest and is in no way affiliated with InterNACHI or its members.
hot water rated pvc? stuff i saw was just like the white pvc, same id and od, same primer/cement
Old 6/24/11, 10:15 PM
Harry D. Vandermeulen Harry D. Vandermeulen is offline
I see it alot on re-pipes here in Florida. The pipe label should state for potable water. It does need to be properly supported.
Old 6/25/11, 9:40 AM
Robert J. OConnor's Avatar
It should be CPVC and not PVC for water supply.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 6/25/11, 11:17 AM
Mark,
What can you tell us about the waste pipes in the second pic? Pic upside down?
Old 6/25/11, 2:10 PM
Jeff Gatt Jeff Gatt is offline
Please Note: Jeff Gatt is a non-member guest and is in no way affiliated with InterNACHI or its members.
It doesn't matter if it is PVC or CPVC for water supply, it matters that the hot water is piped in CPVC because PVC is NOT rater for the temp of hot water.
Also, CPVC solvent glue is required
Old 6/25/11, 2:13 PM
Nothing wrong with pic 2
Old 6/25/11, 3:16 PM
Christopher Currins's Avatar
Originally Posted by jjonas View Post
Mark,
Gravity..
Christopher Currins
Certified, Licensed
Old 6/25/11, 3:17 PM
Originally Posted by ccurrins View Post
Gravity..
Uphill ???
Old 6/25/11, 3:23 PM
Uphill ???
That's what I was "referring" to.
Christopher Currins
Certified, Licensed
Old 6/25/11, 3:40 PM
Pic number 2 is right side up. It was tapped from the copper supply, then about 8 inches down toward the floor, ran along the foundation, split- one way to basement bath sink, and the other way to a "slop-tub". 2 areas actually had a negative slope, and all was not supported except what you see in pic 2. Metal straps to floor joists. OD was 1/2 inch. Client was going to ask for a credit of some dollar amount. He even said, "its coming out!!!!"
Mark Glowczynski
708 473 5116
Illinois Licensed
Old 6/25/11, 3:42 PM
Under the IRC PVC is not permitted for water distribution piping (both hot and cold) ... it must be CPVC. PVC is only allowed for (buried) water service piping.
See IRC Section P2905.5 ... http://publicecodes.citation.com/ico...005_par010.htm
Robert O'Connor, PE
Old 6/25/11, 4:08 PM
That is correct and what I meant to say. CVPC only inside the structure.
Apparently my mind and hand typing isn't working well
Old 6/25/11, 11:28 PM
Mark... I was referring to the waste pipe behind the water supply. I am assuming that section going vertical is a vent pipe? if so, still not best practice, but a broader view would be nice.
Jeff
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
