Old 6/14/07, 1:46 PM
Default Plastic vent if it's not high-efficiency?
When I saw the plastic vent I thought it was a high-efficiency water heater. When I saw the compartment covering the burn chamber I thought it was sealed combustion. It's not. When you open the compartment (no gasket/seal) you're looking directly at a conventional burn chamber access cover, but with various other equipment.
As you can see from the energy label, it's not even close to high-efficiency, so why does it have a plastic vent and all these other components in the compartment covering the burn chamber? Looks expensive. You could get this kind of performance from a conventional water heater.
Might the reason be be limited room for conventional venting?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 6/14/07, 2:09 PM
Michael Larson's Avatar
Default Re: Plastic vent if it's not high-efficiency?
Kenton,
It's fine. The power vent mixes enough room air with the flue gases to keep it cool. Check the mfg. instructions.
P.S.
I have one in both of my basements.
Old 6/14/07, 2:44 PM
Originally Posted by mlarson
Kenton,
P.S.
Thanks Michael!
(303) 717-8940
Old 6/14/07, 4:50 PM
dchew dchew is offline
The efficiency rating of water heaters is much lower than furnaces. The tip off for a high efficency water heater is the fan drive on the flue. When in doubt, check the manufacturer's data sheet.
It may be your picture, but is the bottom of the TPR tube flush with the platform?
Old 6/14/07, 8:13 PM
Nope, went down to a floor drain.
(303) 717-8940
Old 6/14/07, 8:33 PM
Jason1's Avatar
Jason1 Jason1 is offline
Please Note: Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Standard, mid or high-efficiency models can be power-vented units that need electricity to operate. This type of heater is not usually affected by changes in the air pressure in the home but can contribute significantly to building depressurization, affecting other combustion appliances.
High Efficiency venting????? Matt Lewis Inspecting HVAC Systems 8 11/10/07 12:31 AM
Gas changes for plastic vents in Canada rcooke Canadian Inspectors 0 7/30/07 3:15 PM
Hart & Cooley plastic furnace vent apfaff Inspecting HVAC Systems 2 8/15/06 4:20 AM
Proper Vent - High Eff. Gas Furnace rkuntz Inspecting HVAC Systems 8 1/13/06 11:18 PM
