Inspected a house today built in 1999. Water line were plastic w/ glued fittings munufactured by Charlotte Pipe. And were marked "Flow Guard Gold". Should there be any concerns w/ these products?
thank-you
Flowguard seems to be a good pipe. However, if you find it on the exterior of the home it must be painted. This pipe is can be damaged from UV rays and can also be damaged if undergound with pesticides.
You someone is installing exposed CPVC piping on the exterior of a house, the installer must have issues. |
We see it all the time down here, mostly for hose connectioins.
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 10 | 1/11/06 10:53 PM |
