Old 8/29/08, 3:17 PM
John Evans John Evans is offline
Default Please Explain
Came across this plumbing component this morning. Water was dripping through the drain pipe. Had to break the photos into two due to shelving located in front of the wall. Could someone explain the purpose of this component? Should water be continuously dripping? Thanks.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 8/29/08, 4:20 PM
Michael Larson's Avatar
Default Re: Please Explain
It's a watts pressure relief valve(adjustable.
Sometimes used in place of a an expansion tank in some jurisdictions.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 8/29/08, 4:33 PM
Is it normal to continually drip? Why the pressure relief valve at this location just above the main water shut off valve?
Old 8/29/08, 4:54 PM
No, it should only discharge when the pressure setting it exceeded. It probably needs replacement.
Michael Larson
Hudson, WI
InspectraPro
and
Old 8/29/08, 5:08 PM
Thanks Michael.
Old 8/29/08, 11:17 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Also, with the leg terminating their, that outlet box may not be in the safest spot. Just a thought. It probably meets all the specs and blah blah blah. But you never know what could happen.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Explain this one, Michael... jwilliams4 General Inspection Discussion 29 7/2/08 9:20 PM
A fake (temporary) site I built to help explain where we are going with this... gromicko Miscellaneous Discussion for Inspectors 63 6/8/07 2:23 AM
Please explain.... abolt Electrical Inspections 6 3/11/07 3:38 PM
Try to explain this one to me?? crichiii Inspecting HVAC Systems 17 12/16/06 10:15 AM
Some one please explain mcotten Inspecting HVAC Systems 5 2/4/06 12:23 PM
