New construction,.. ABS Waste lines are supported by metal plumbers tape. I know they are no longer recommended (IRC & UPC) but do I make a huge issue over it??
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
As for the waste lines, well ........ |
How about this one. Most homeowner fixes always seem to amaze me. This homeowner literally used a blow torch to bend this waste line, then supported it with a good ole' extension cord. Not only that...Waste water runs uphill. "Click to Enlarge" Attachment 8846 Last edited by dvalley; 10/7/07 at 5:42 PM.. |
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you are refering to plumbers strap then it is ok where I plumbed under UPC. I liked to use PVC J hooks because they worked and looked better.
| Asbestos duct tape reporting | hspinnler | Ancillary Inspection Services & Additional Topics | 7 | 12/4/08 3:05 PM |
| save a plumbers job | John C. Morgan | Plumbing Inspections | 6 | 2/9/07 1:07 AM |
| Asbestos tape on hot air duct joints | jjensen2 | Ancillary Inspection Services & Additional Topics | 4 | 1/20/07 12:31 PM |
| Loose tape and loose popcorn texture | cdewitt | Interior Inspections | 6 | 6/9/06 6:14 PM |
| electrical tape in panel | dnice | Electrical Inspections | 5 | 3/17/06 11:41 AM |
