I am not sure what this is. The house has 3 water heaters and a boiler. The boiler appears to be connected to the radiant floor heat. The vertical copper pipe goes to a floor drain. Is this some kind of zone valve or relief valve? Could it be the backflow preventer? The boiler is in another room on the other side of the house.
Michael Merino Merino's Home Inspection & Education Inc. "Not just an Inspection, an Education"SM Phone/Fax 708~535~6057
| Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America) |
Could be some sort of flush valve system Mike.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Thanks Mr. Larson. I am glad that I was thinking in the right direction.
I will make it easy from the PDF
Good catch Mike APPLICATION Designed for installation on potable water lines to protect against both backsiphonage and backpressure of contaminated water into the potable water supply. Assembly shall provide protection where a potential health hazard exists. |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 3:28 PM |
| Plumbing Code changes | mcyr | Plumbing Inspections | 0 | 9/8/06 6:47 PM |
| A few useful posts - I forget from whom | jmichalski | Plumbing Inspections | 12 | 3/30/06 10:06 PM |
