Old 3/30/07, 11:09 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Plumbing in cold region, snow in winter
Are the pipes ran any different ? Any provisions to stop supply lines from
freezing .
David
PHI
Old 3/31/07, 7:58 AM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Plumbing in cold region, snow in winter
In MO. KS. not a good plan to run the lines in attics or cantilevered ares that hang out over the great outdoors.
Plumbing in exterior walls is done but not such a great idea either.Service lines are buried @3'.
Materials? The DIY'ers may use cpvc because it's easy to use but it splits like crazy when it freezes and the split is hard to isolate when repairing.
Copper is the most commonly used.Splits from freezing are easy to cut out and replace and if you can't keep water out of the lines during a sweat repair just stuff them with bread,It absorbs the water long enough to make the repair then dissolves or flushes out.
Plumbers are really beginning to use PEX alot .It's so new I think the jury is still out on that.
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
Plumbing Code changes mcyr Plumbing Inspections 0 9/8/06 5:47 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
