Old 7/20/11, 7:32 PM
Stan Croenne Stan Croenne is offline
Default Plumbing at disposal
At my inspection today, I have the drain line coming out of the disposal dropping down into a P-trap configuration made out of pressure fitted piping. The pipe then rises 4" to a T fitting to meet up with the other bowl drain line and then travels through an approved p-trap right next to it and then into the horizontal pipe to the wall drain. There are two P-traps side by side. It doesn't look right to me. Sorry no picture. Thoughts?
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/20/11, 7:38 PM
Jeffrey R. Jonas's Avatar
Default Re: Plumbing at disposal
A pic would sure help. As long as each fixture only drains through ONE trap, it is acceptable (in my area). As for the materials... what are you calling a "pressure fitting"? Also unclear on the fall/rise of the waste lines.
Do you not take pics of defects or concerns?
Old 7/21/11, 12:17 AM
Robert J. OConnor's Avatar
I assume your area is on UPC based codes ... but most areas are on IRC based codes that permit 2 fixtures on one trap and trap arm/vent.
It's hard to tell from the description, but it sounds like that may be a double traped installation, which would not be acceptable. That looks like this ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 7/21/11, 12:23 AM
Uhh... Isn't that what I said?
I didn't say each fixture must drain through a seperate trap.
Musta been the accent!
Old 7/21/11, 12:27 AM
... each fixture only drains through ONE trap, it is acceptable ...
I took that to mean your area required a trap for each fixture (two fixtures and two traps) ... my misunderstanding if that wasn't the intent ...
Robert O'Connor, PE
Old 7/21/11, 12:29 AM
Like I said, musta been the accent. My intent was to indicate that a fixture is not allowed to drain through more than one trap. Better?
Old 7/21/11, 8:06 AM
Thanks guys, I take tons of pictures to put in my reports. I was not able to load the picture for this application. The pipe leaves the disposal downward 4" over 4" up 4" to a T fitting. Next to that is the P-trap that goes to the wall drain. When looking at it, it looks like 2 P-traps right next to each other. Food from the disposal travels through 2 P-traps then to the horizontal drain that leads to the wall. When I tested the right drain, (disposal side) I could see water make its way to the left drain. It just doesn't look right to me. It doesn't look like a standard set up when installing a disposal. Stan
Old 7/21/11, 10:36 AM
Jeffrey R. Pope's Avatar
This makes it wrong under any model code.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
San Antonio Air Conditioning, Plumbing and Heating Services and Repair Don Hatcheson Inspecting HVAC Systems 0 7/31/09 1:51 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
Plumbing Code changes mcyr Plumbing Inspections 0 9/8/06 5:47 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
