Old 2/2/06, 12:52 AM
darnold1 darnold1 is offline
Talking Plumbing drain lines should run downhill at a slope of
Which is it? A. 6-12 pitch B. vertical C. 1/4" per foot D. 3" per foot
send to akron112@aol.com THANKS!
Old 2/2/06, 12:55 AM
Ted Allen Ted Allen is offline
Default Re: Plumbing drain lines should run downhill at a slope of
That looks like one of the questions on our entrance exam.
You would not be taking a test, now, would you.
it's D
Old 2/2/06, 1:11 AM
Monte Lunde Monte Lunde is offline
Please Note: Monte Lunde is a non-member guest and is in no way affiliated with InterNACHI or its members.
Let see Waste line, drain line for a Slab, Basement Floor, First floor or second floor or are we talking "what is the minimum slope for a Waste/ Drain line". I would check C for minimum slope.
Old 2/2/06, 6:07 AM
phinsperger's Avatar
Both B and C are correct but if your taking some sort of test they are probably looking for C.
Old 2/2/06, 7:45 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
IRC 2003
P3005.3 Horizontal Drainage piping slope. Horizontal drainage piping shall be installed in uniform alignment at uniform slopes not less than one-fourth unit vertical in 12 units horizontal (2 percent slope) for 2 1/2-inch (64 mm) diameter and less, and not less than one-eighth unit vertical in 12 units horizontal (1-percent slope) for diameters of 3 inches (76 mm) or more.
Old 2/2/06, 8:27 AM
It's "D" I tell ya. Don't go listnin' to all these folks with them thar fancy CODES.
Old 2/2/06, 8:36 AM
rwand1 rwand1 is offline
1/4 per foot. Anything less and anything more - flush twice.
Old 2/2/06, 9:44 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
1/4 per foot min, and 3'' per foot max, unless vertical. anything below 1/4 per foot won't drain right, more than 3'' per foot and less than vertical, and all the water will drain, but not the solids. then they dry, clog, mess, chemical suit and resperator, clean up crew, plumber then staying at the Y, second mortgage, devorce, allamony, child support, wellfare, drinking problem, sleep in box behing bar, well you get the idea.
Maximum slope of drain line? bsmith Plumbing Inspections 6 4/16/07 1:28 PM
French drain tied into main drain rwashington Plumbing Inspections 6 2/16/07 11:04 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
need opinions on drain slope bking Plumbing Inspections 5 3/12/06 5:54 PM
