Amalia Markous is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hello everyone,
Any time I use a sink, toilet, or my washer, the waste water floods my basement! The white plastic pipe connected into the black PBV pipe is overflowing., What's wrong?! Can I fix it myself?? Is it an expensive repair? Thanks a lot. Amalia Markous |
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Posted their link in another thread. It is a Plumbing Company!!! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
So how does this work?
How does Amalia make money out of a post like that? |
Great Catch thanks...Roy
Thanks Jonas I would not repond to this either as there is no picture and suspicious comment.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
gaurav sharma is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you find any leak, so should be follow these some things like-
Turn off the main water valve. Dry the surface by draining the water to avoid any sort of mishap. As a bathroom floor becomes slippery after such leakages which can lead to some serious accidents. You should try to collect as much water as you can in buckets or containers. You should work carefully with hot water lines to avoid any type of injuries. If you find a hole in your pipe, wrap it up with a piece of rubber. For temporary fixation you can use adhesives like quick fixes. For permanent solution of leakage problem, you need to use certain hardware equipments, like hose clamps, electrical tape, plumber epoxy putty. __________________ Leaking Pipes |
SPAM!!! And all around BAD info!!!
This entire thread needs to be removed! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Check his website...
not only a Spammer but another IR Inspector.... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Really? Electrical Tape for Plumbing Repair? Does it perform better than Duct Tape? LOL Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I wonder what the team thinks:
http://www.allkarepropertydryingout....-the-team.html InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
An IR Inspector using "electrical" tape for "plumbing" repairs.
LOL.... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
[QUOTE=gaurav sharma;869861]If you find any leak, so should be follow these some things like-
Turn off the main water valve. Dry the surface by draining the water to avoid any sort of mishap. As a bathroom floor becomes slippery after such leakages which can lead to some serious accidents. You should try to collect as much water as you can in buckets or containers. You should work carefully with hot water lines to avoid any type of injuries. If you find a hole in your pipe, wrap it up with a piece of rubber. For temporary fixation you can use adhesives like quick fixes. For permanent solution of leakage problem, you need to use certain hardware equipments, like hose clamps, electrical tape, plumber epoxy putty. __________________ |
ayeshaa akter is a non-member guest and is in no way affiliated with InterNACHI or its members.
You know what kind of smell I’m talking about – that rotten eggs smell, the smell of sewer gases. You’ll know it when you smell it and you certainly can’t miss it. But sometimes you can’t tell where it’s coming from or what’s causing the problem. Here are some suggestions for handling this unpleasant – and potentially dangerous – plumbing problem.
If the smell is coming from the shower or bathtub: Again, check for leaks in the traps in these drains. Since it’s not always as easy to see this plumbing as it is the plumbing under your sink, remove drain covers to make sure there’s water standing in the drain and that the water appears undisturbed. If there’s no water visible or if you see movement or notice the smell is stronger, it may be that you have a leak somewhere in the trap and the reason you have that smell is because that water barrier we talked about earlier is gone. If the smell is coming from the toilet: Again, there’s a reason for that water in your toilet bowl, other than the obvious. That water is another barrier between the sewer system and your house. It traps those sewer gases on the outside. Most toilets are also constructed to have a trap underneath, similar to your sink. So if you have no water in your toilet bowl it could be that you have a leak in that trap. Check the wax seal around the base of the toilet, as well. These seals need to be replaced ccasionally and a faulty seal could be the source of your odor problem. For more information, click here, plumbing |
| Do you have Kitec plumbing | rcooke | Canadian Inspectors | 1 | 9/20/11 10:01 PM |
| San Antonio Air Conditioning, Plumbing and Heating Services and Repair | Don Hatcheson | Inspecting HVAC Systems | 0 | 7/31/09 1:51 AM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 2:28 PM |
| Plumbing Code changes | mcyr | Plumbing Inspections | 0 | 9/8/06 5:47 PM |
| A few useful posts - I forget from whom | jmichalski | Plumbing Inspections | 12 | 3/30/06 9:06 PM |
