Old 9/22/10, 6:59 PM
Bruce A. King's Avatar
Default Plumbing fix
Lets see, this PEX joint is leaking so maybe I can find something here in the garage to fix it with...... A little glue and a little PVC should do the trick
Thats PEX going into the wall also.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/23/10, 12:25 PM
Sean Fogarty's Avatar
Default Re: Plumbing fix
Did it function properly at the time of the inspection??
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 9/23/10, 1:51 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
Note the complete lack of 37 shutoff valves, Recommend hanging cloths or heavy tools on pipe immediately.
Old 9/23/10, 5:52 PM
Not in the entirety since proper installation is part of a correctly functioning system
704 301-3207
Old 9/23/10, 6:13 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
That is known as a Polish Reverse Peltier Loop. As the water is delivered from the city supply or the well to the home, the water then travels through the "Peltier loop" where it picks up external heat and helps precondition the water before it enters the water heater. This way the water heater does not need to use as much energy, since it does not need to raise the water temperature as many degrees. Modern technology at its best.
Or it could have been a Harry Homeowner fix to a leak.
Stephen Stanczyk
Old 9/24/10, 6:40 AM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
I thought that was an Australian Drain Relief Circuit. It pre-spins the water so it can go down the drain easier.
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Plumbing statement review rbibler Plumbing Inspections 25 7/11/10 4:22 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
Plumbing Code changes mcyr Plumbing Inspections 0 9/8/06 5:47 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
