Good morning,
Yesterday, as my wife was so kind to let me sleep in for once, I was awoken anyhow by a couple of gallons of water coming through my first floor ceiling into my family room. My two smallest were play with a few toys made for water in about 4 - 5 inches of water in the bathtub above. They are nothing more than a few little race cars that change color when put in cold water. When they were done playing, my wife went up there and drained the tub. Within a half hour she noticed water dripping from the ceiling directly below the bath tub that soon migrated across the entire ceiling. Here is the kicker, after turning off all the water and draining the lines, I pulled a small section of the ceiling out to get a look up in the ceiling where the damage started. About 2 gallons of water came out. After drying out a bit I could not find any burst pipes or damage anywhere. My first instinct was that this might be from a frozen pipe, because this plumbing is only a foot from an outside wall and the temps here in the northeast lately have been in the teens at night. Next, I decided to try and turn the water supply back on slowly to see if I could pinpoint a leak. NOTHING LEAKED. Therefore, I tried filling the tub and draining slowly. Still NOTHING. I had a contractor come over and he could not find a leak either. The drains have been clear and are still clear. His only guess as to how all of this water may of ended up coming through the ceiling is that there could have been enough of a clog above the P-trap where the tub drain comes into the line that might have caused an uplift in the draining and it perhaps came down around a bad seal at the drain stopper level. Any and all ideas/suggestions would be greatly appreciated. Regards, Steve |
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Any way of checking the over flow drain
Ps when our kids took bath with toys it look looked like marine world maybe it was splashed over the sides. |
If the the tub is older, when you put extra weight in it such as kid's playing around and jumping up and down in the tub or adult standing in it. It flexes at the drain basket and allows water to flow under the lip.
Gerry Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
Stephen,
As we all know, the leak may not be where we notice that it "appears" to be leaking from. What about the wax ring at the WC??? Any chance of ice buildup at the exterior wall that melted when the kids had their hot bath? (I know you stated 2 gallons worth, but was it really? A small amount looks like a lot more, when you're not expecting it). Pictures??? Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
All,
Thanks for the great inputs. I'm going to try and quickly address some of the things that were brought up. I'll try and post pics tonight when I get off work. I work for and aviation company during the day.... Wayne - good point, I think I'll try and test that overflow drain when I get home this evening, that might verify the original theory of the contractor that came to my house. Gerry - There was only 4 to 5 inches of water in the tub at the most. The only thing in the tub was a few plastic toys the kids were playing with while sitting in the floor on the outside the tub. They weren't actually taking a bath. Age of the tub is 11 years. Jeffrey - The only place that was wet this far up into the walls above was right at the tub. The insulation I pulled out was soaked up to the point vertically where the overflow drain is located. Everything else was dry (except the track across the ceiling) as far as insulation goes beyond 2 feet of the tub. Also, none of this happened until 30 minutes after the tub was drained. I've since turned all water on, flushed all toilets, filled tub up and drained again, ran water in sinks, etc.. everything is still dry. I still have the buckets of water that we managed to collect. I would estimate at the least 2 gallons + what is soaked into the insulation I pulled out.... Regards, Steve |
Stephen,
Is there a washing machine on the other side of the tub wall or on the same level of the home? |
David,
Nothing on the other side of the wall or withing 6 feet of the damaged area. Regards, Steve |
It can't be the overflow piping, this drains into the same waste pipe below it.
Unless it is cracked or broken where you can't see it, before it gets to the waste pipe...
Is it a fiberglass tub unit?
More than likely it is leaking around the drain when pressure is put on it. Our shower is torn apart while we wait for a new drain to arrive. Greg Bell Titusville, Fl 02111507 Serving Central Florida
That pipe could be cracked, I'll get a closer look this evening. I don't think the tub is cracked because there was no one in it when this happened or prior to. We've since filled it up a few times and no leaks appear. If not the over flow pipe, my guess is the seal against the tub where it connects. I'll be sure to come back and post whatever I find. Thanks again for all the ideas.
Regards, Steve |
there does seem to be a direct correlation between kids playing and water leaks through ceilings below bathrooms...I stopped being amazed by this long ago ..
Check the shower head connection in the wall. Ask the kids if they turned on the shower while they were playing.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Got home this evening and with some assistance, took a pitcher of water and poured directly into the tub drain lever area. Watching from the other side of the wall through an access panel (I just installed) I immediately saw where water was getting through the drain pipe. I found the attached diagram of a tub drain and marked it up in MS Paint to show where the water was coming through. Makes sense now because all of the wet fiberglass insulation was at this point and below.
I started searching the web to see if anyone had ever experience a similar problem with a P-trap freezing and water backing up a drain and found quite a few. http://www.home-built4u.com/house-insulation.html |
| Orange County Home Inspections | whandley | California Inspectors | 12 | 5/18/11 6:35 AM |
| Coeur d'Alene, ID Home Inspectors | rspriggs | Miscellaneous Discussion for Inspectors | 12 | 1/8/09 5:16 PM |
| Buckeye Home Inspections Service Area | sboyd2 | Miscellaneous Discussion for Inspectors | 3 | 9/4/06 7:21 PM |
