mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
I called out an excessive tail piece yesterday as the trap was over 36" away from the sink drain (start of tail pipe). Builder came out today and says is within 47" and it is fine. What is your opinions? Thanks.
I assume you're referring to the trap arm (a horizontal pipe) rather than the tail piece (a vertical pipe).
The maximum trap arm length depends on the pipe size. For instance, a 1-1/4 inch pipe can have a trap-arm length (from trap to vent) of 30 inches. A 4 inch pipe can have a trap-arm length of 10 feet. At 47 inches, it should be at least a 2 inch pipe - which can have a maximum trap-arm length of 5 feet. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
This is U.S. standards - I just noticed you are up North.
Maximum tail piece length is 24 inches except for clothes-washer stand pipes.
Again, U.S. standards. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Doesn't matter the length of the tailpiece (which is excessive), I wouldn't like to see plastic nuts and washers in the crawl. If it leaked no way to tell and the air test for the code inspection does not include tailpiece or P trap. Agree with Jeff 24 inches is max.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Check your BC code. In Ontario 48 inches is OK. The trap is quite often below the floor for kitchen island sinks. |
| Trap help | dbucknavich | Plumbing Inspections | 29 | 8/8/07 9:48 PM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 3:28 PM |
| Plumbing Code changes | mcyr | Plumbing Inspections | 0 | 9/8/06 6:47 PM |
| A few useful posts - I forget from whom | jmichalski | Plumbing Inspections | 12 | 3/30/06 10:06 PM |
