Todays inspection was interesting. Homeowner/handyman built log home. This is the only plumbing vent I noticed. Everything seems to drain fine and there is no plumbing upstairs.
Comments, good and bad are welcomed and encouraged. Pictures are of vent inside at the washing machine drain and outside. Thank you. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
That almost looks like an S trap.
Arent dryer vents suppposed to terminate to the exterior of the home. |
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Table 3 Maximum fixture units on one stack
When looking at the pictures, there is an arrow pointing to the PVC. The PVC is a drain for the washing machine and at the "Y" it goes outside for a vent.
Yes, the flex vent is for a dryer that is not hooked up. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
tom |
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
New Hamsphire Plumbing Code is the International Plumbing Code 2000 if I am reading correctly:
http://www.nh.gov/plumbing/ Don't know when it was adopted, where it applies, or under what plumbing code this structure was built. Only the plumbing code that was in effect at the time of construction applies here. That said, International Plumbing Code (commercial) and its International Residential Code (resdiential) counterpart allows for a minimum main vent of 1 1/2" as shown....although for your region it should have an increase in size to at least 3" to prevent frost closure where it exits the structure... And as jason1 said, there are required clearances from lot lines, openings, and grades just as mentioned. But under the IPC and IRC a through-the-wall vent is not permitted to be the only vent for the structure. Section P3102.1 of the 2000 IRC requires that EVERY BUILDING shall have a stack vent or vent stack and such a vent shall run undiminsihed in size and as directly as possible from the building drain to "open air above the roof". A side wall vent is not allowed as the ONLY vent in a structure according to NH plumbing code. But again, it depends when this installation was permitted and done. It may have met 'code' at the time of installation. Last edited by homebild; 2/11/07 at 11:44 PM.. |
jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hombild is right. These sidewall vents are intended as fixture vents only, and not the ent for the building drain or stack.
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's an "S" trap, the vent connection should not be below the trap weir.
I drew it how it should be. What are the unprotected wires? |
The wires questioned are in fact the well pump wires. The pump is about 50' from the house. The water line appeared to be made out of hydraulic hose and fittings, a 30 gallon tank sitting on a shelf above the picture
There are several marginal type conditions inthe house. As posted originally, this Log house was built by the owner and definately has the qualities of an amateur. Thank you all for your input. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
| Plumbing vent | cbono | Canadian Inspectors | 13 | 10/13/07 11:58 AM |
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 4 | 10/12/07 6:38 PM |
| Plumbing Vent...why so tall? | jvogan | Plumbing Inspections | 16 | 8/17/06 12:02 AM |
