Can someone provide me with a link or info on why caulking the bottom edge of a plumbing vent flashing is not recommended.
Thanks in advance! Josh |
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
OK. I'll try another. Comments on this flashing installation. Would you call it out not being under additional 2 courses and bottom edge being sealed?
Improperly installed roof flashing using fabricated asphalt roofing materials. Asphalt roofing material tends to break off or deteriorate rapidly when used in this application. Unfortunately, flashing of this type is routinely approved by local building authorities and may be considered a local building practice. Recommendation: Evaluation and replacement by a licensed roofing contractor.
Looks like it's nailed down at the bottom. Someone put mastic there for "extra protection" and I don't see anything wrong with it. Water isn't supposed to get underneath the flashing anyway, so there is not a valid argument for leaving it open to drain. I prefer to see the shingles overlap past the roof penetration like Mr. Currins example. It's just a judgment call. If it's not leaking, I probably would not recommend that it be replaced. You'll see much worse. I see mastic like that a lot.
Glad to see your using your common sense Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Until the asphalt flashing starts cracking, which in Ohio, will be in 2 or 3 years, allowing water from rain, snow, and ice to penetrate.
It had a regular plastic/rubber flashing around the pipe that wasn't cracked. The just dressed it up with mastic for "extra protection". I see that all the time.
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 5 | 10/12/07 5:38 PM |
