Old 8/19/08, 2:44 PM
mjohnson6's Avatar
mjohnson6 mjohnson6 is offline
Send a message via Yahoo to mjohnson6
Please Note: mjohnson6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Question What is a Point Well?
What is a point well.
What considerations should I be thinking of when inspecting one?
I'm assuming it's some type of water well, but im not 100%.
Open for "point well" taken discussion.
Old 8/19/08, 3:05 PM
Default Re: What is a Point Well?
At the risk of sounding arrogant and sarcastic, which although I am this is not intended to be...
If you don't fully understand it, don't inspect it till you do.
This is a start: http://hydrology1.nmsu.edu/hydrology/wellpoint.htm
Abraham Lincoln
Old 8/19/08, 3:06 PM
Michael Larson's Avatar
Are you speaking of a driven well that uses a sand point?
Shallow well less than 25 feet.
Michael Larson
Hudson, WI
[/I]
Old 8/19/08, 4:32 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Mike,
Must be a well point. Used for driven wells, as you said. Can go deeper than 25 feet, depending on conditions. Uses a packer assembly to allow water from the pump down the pipe, where it changes direction n the assembly and heads up a 2nd route. A pipe within a pipe with nozzle and venturi in the packer. System uses a 2-pipe jet-pump.
Old 8/19/08, 4:34 PM
Thanks for the clarification Joe,
Michael Larson
Hudson, WI
[/I]
Old 8/19/08, 9:11 PM
jbettencourt jbettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Matthew, listen to Joe he knows his wells.
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
