Old 11/22/08, 1:15 AM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default polybutylene?
I found a little of this hidden in my inspection today. I could not see any data stamped onto the piping although I am thinking it is polybutylene. Can someone confirm please? Thank you.
Old 11/22/08, 3:08 AM
Brian E. Kelly's Avatar
Default Re: polybutylene?
Looks like PB pipe from here
Old 11/22/08, 6:12 AM
David P. Valley's Avatar
If it is PB, it's not an issue unless you see crimped fittings.
Old 11/22/08, 6:54 AM
John Evans John Evans is offline
Certainly appears to be PB, but you will normally find the PB2110 stamped on the surface.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 11/22/08, 9:25 AM
Joe Funderburk, CMI's Avatar
David, can you substantiate that statement? I've never heard that before. Most would say plastic fittings are MORE of an issue than crimped fittings. I simply say this anytime I see PB (the statement below is actually required by the State of NC whenever we see PB...but I modified it slightly to put in a web link and advising them to call a plumber):
"Polybutylene plastic plumbing supply lines (PB) are installed in the house. Polybutylene has been used in this area for many years, but has had a higher than normal failure rate, and is no longer being widely used. Copper and brass fittings used in later years may have reduced the failure rate. For more information about PB, see http://www.pbpipe.com and other Internet resources and/or rely on the evaluation and advice of a licensed plumbing contractor prior to the close of escrow."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/22/08, 12:30 PM
Joseph Hagarty,  CMI's Avatar
I would not suggest saying that PB 2110 is acceptable because it does not have crimped fittings.
Our Office recommends that all PB be replaced when found to be present.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 11/22/08, 2:38 PM
The type of fittings used with PB are not the only problem. Chlorine added to public municipal water supplies will cause deterioration of the pipe.
Old 11/22/08, 8:46 PM
wsiegel wsiegel is offline
I that a plastic dryer hose in that picture???
Old 11/23/08, 11:21 AM
mnicholet's Avatar
Yes it is venting a bathroom vent to the exterior wall above some ceiling tiles in a basement.
Old 11/23/08, 7:37 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
I would recommend they change out the dryer hose for safety reasons. Plus I agree you have PB on your hands. I would recommend a replacement.
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Old 11/23/08, 11:12 PM
pabrioux pabrioux is offline
Since that "plastic hose" is just a duct for a bathroom exhasut fan, not a dryer, it should be ok, no? You might recommend that it be the insulated type if it goes directly to the outside wall.
Paul-Marc
Old 11/24/08, 8:36 AM
Paul-Marc
Metal is required around here...
Larry Kage, CMI
231 929 3525
Old 11/24/08, 11:39 AM
Ok, I didn't know that. I could see it for a dryer vent, but thought that for a bath exhaust fan a plastic type would be adequate.
Mark, do you know what's required out there on the island?
Paul-Marc
Old 11/24/08, 12:44 PM
Yea I missed his post that the hose was venting the bathroom exhaust fan how I don't know fell asleep I guess or just assumed it was for the dryer lol regardless I always recommend installing metal over plastic for any type of venting especially those with any type of heat source.
Bill Boerner
(314) 805-2137
Old 11/24/08, 8:32 PM
Most insurance companies around here are not insuring homes with PB water lines. Replace them. Too many issues either way.
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Polybutylene Plumbibg? gbrasseur Plumbing Inspections 29 2/26/07 4:28 PM
polybutylene plumbing pwathen Plumbing Inspections 2 2/23/07 6:09 PM
polybutylene plumbing website kgerhauser Plumbing Inspections 4 2/10/07 8:53 AM
