Somebody asked me how we treat PB - Depending on condition I have different comments, BUT here is one ............
The primary water supply lines in the home are "Polybutylene Plastic" (PB). This type of plumbing has experienced a higher than normal rate of leaks or plumbing line failures (often at fittings – both plastic and metal), and some Polybutylene Piping has experienced premature system failures. There have been several "Class Action Lawsuits" involving the product. Although there are NO requirements that Polybutylene Piping be removed from a house with it, SOME people prefer to remove it. Polybutylene has been REMOVED from the National Building Codes list of acceptable plumbing supply line material for NEW houses. For more information on this material, see http://www.polybutylene.com, or do a GOOGLE search for Polybutylene Piping. We also STRONGLY recommend that you do your own research on this type of plumbing system and rely on the evaluation and advice of a licensed plumbing specialist prior to the close of escrow that was CONTACTED by you and NOT a seller or real estate agent. Several highly competent plumbing contractors familiar with Polybutylene Piping and its problems are: Dick Ray @ Shawnee Mission Plmbg, Htg & Cooling - (913) 888-0550 American Plumbing Company @Olathe, KS (913) 782-0186 |
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I did my investigating with the Quebec CCQ and since over 500,000 homes have had this piping installed and although poly-B has been replaced by the super-pex, poly-b the CCQ has no intention to ask for removal and does not encourage scaring the public for no reason. Legends will remain legends!
I often demonstrate my shark push fittings Salut! Beauchemin, Marc-Andre |
I have a similar statement or paragraph regarding PB. I also make sure my client understands what PB is and the problems that can arise with it. I also let them know I have personally seen PB fail, but some people with this type of water line never seem to have a problem. I also inform the client some insurance companies will not insure a home with PB (and a special rider may be required).
What type of chemicals do you have in your public water systems up there? Did you know that chlorine weakens PB pipe over time? B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
For me, this is a "no-brainer." Once a product has been determined to be defective by the manufacturer or a court of law, I will not endorse it - period. I don't care if it's in pristine condition.
Polybutylene piping systems are the subject of class-action lawsuits and have been determined to be defective. As such, we do not endorse this system regardless of its condition at the time of the inspection. You should consult a qualified plumbing contractor during your inspection contingency period to evaluate the plumbing supply system, because the cost of re-piping the residence may significantly affect your evaluation of the property. I have a similar narrative for Cal-Shake roofing material and specific horizontal furnaces. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
PB 2110
- Polybutylene piping present and detected in areas of the home. - Recommend plumbing review to determine the extent of PB within the home along with obtaining estimations for replacement of the piping at this time. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
| Bonding both hot and hold supply pipes | kshepard | Plumbing Inspections | 22 | 5/4/08 8:00 AM |
| Bonding Piping 101....Good To Know ! | pabernathy | Electrical Inspections | 37 | 4/28/07 11:25 AM |
