Old 10/7/09, 3:22 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Possible asbestos vent duct?
Is this asbestors? This is venting the water heater in the garage.
What would be the write up ?
Find an InterNACHI certified Utah Home Inspector (and anywhere else in North America)
Old 10/7/09, 5:01 PM
Sean Fogarty's Avatar
Default Re: Possible asbestos vent duct?
If you think it is, federal law requires you to assume that it is, until the suspect material is tested. I would say by looking at the metal, it is past it's prime anyway. The easiest solution is to have it tested.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 10/7/09, 5:57 PM
Jeffrey R. Pope's Avatar
Yes. It's a Transite pipe, which is a known asbestos-containing-material.
The heat vent includes a Transite pipe, which is comprised of a solid, cement-like material that is known to contain asbestos fibers. Admittedly, these fibers could not easily escape from within the material, but the majority of heat vents, and certainly those that pass through attics, are required to be double-walled, or Type-B. Due to the fact that an imperceptible crack in a single-walled vent pipe could result in a fire, we recommend that the Transite pipe be replaced with a modern double-walled steel type.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/9/09, 2:14 AM
thanks everybody
Asbestos.............What is asbestos? mkyriacou Ancillary Inspection Services & Additional Topics 2 9/17/09 5:03 PM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:11 PM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:09 PM
Is this a competent asbestos removal job? Is our basement now a biohazard? David Paterson Ancillary Inspection Services & Additional Topics 5 1/16/07 7:16 PM
