Gentlemen,
The attached picture is of a 3/8 inch water line that is connected to the cold water line under the sink in a bathroom. The bathroom is a full handicap bathroom with a shower designed to roll your wheelchair in, and a 2nd drain in the middle of the tiled floor for the occupant to drip into after the shower. This is the trap for the floor drain. I wrote this up as a health safety hit because I don't think you can connect potable directly to the drain like this. I got a call from the person who remodeled the bathroom saying that is was required for code for a drain that doesn't have a fixture on it to allow you to put water in the trap. I told her I needed to do some homework. Can you guys help me out? I am not finding it in the residential code. Mayby the plumbing code? I don't have that one. This is a single family home. At a minimum I would think it would need some type of vacuum breaker or air gap type connection. I didn't see it, but I am told it has a checkvalve. Appreciate your input. |
That connection should go to a trap primer and would be required to maintain the water level in the trap so no sewer gas will escape. http://www.plumbersurplus.com/ProductList.aspx?Cat=776
Regards Bill Last edited by wcottrell; 10/30/06 at 6:57 AM.. |
There are multiple references but a direct connection between the potable water supply and the the waste system is not proper.
2003 IRC: Quote:
Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
There must be an air-break (air gap) or a mechanical back-flow device. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff,
How do we know its been improperly installed there is no picture of the connection under the sink. There may be a trap primer under the sink. Regards Bill |
Good point and only John can tell us for sure: Quote:
You cannot attatch to a drain line in this manner. Approved fittings are required. It is attached below the weir of the trap. If that copper line has an air-break or a check-valve, it then becomes a drain line (after the point of the break or valve), which would require a downhill slope. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 10/30/06 at 5:02 PM.. |
Jeff
Great point Thanks Bill |
Unfortunately I didn't take a picture of the connection below the bathroom sink where it is tied to the potable line. It is a regular compression fitting shut off valve connected to a Tee in the potable line before the sink shut off valve. The subcontractor that installed the line says that there is a check valve. If I check that valve, and it is a trap primer or vacuum breaker valve, it might be ok. But, as Jeff pointed out, it would still need to be above the weir of the trap. Anybody got one of those real good diagrams that they could share?
| Water line repair program. | dmacy | Plumbing Inspections | 2 | 1/10/07 11:22 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 10 | 1/11/06 10:53 PM |
