Did an inspection today with a power vented John-Wood Superflue. This was a single power vent system. IPEX run of approximately 16 feet and 4 elbows. 2" line.
As this was an owner inspection(11 month warranty inspection), I was informed that the tank would not deliver hot water at all times. Mostly on windy days. Heat was not constant. I have had this happen on other 2 vent systems and the span was too long but when researched the span, it appears this has a proper span. I did notice however, that there was no combustion air line for the system and the furnace was a high efficiency furnace. Anyone else had the issue of heat loss in these superflow tanks or similar? Kind of stuck in this one or maybe somethings staring me in the face I can't see the problem for looking. Any assistance would be appreciated. Thanks Allan Allan Berdahl Aarlan Home Inspection Services Calgary, Alberta Bus: 403-808-5355 Cell: 403-803-4064 Fax: 403-204-8863 Email: aarlan@telus.net |
I think max distance is 40 feet , Each elbow is = to 5 feet times 4 =20 feet
So if as you say 16 feet plus 20 feet comes in under the 40 foot rule . Sounds like air starvation . Is there an HRV and is it set up correctly . Could be a simple as adding a two inch air supply with a fish hook at bottom to add air if needed but this is not our call.. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
| Water heater expansion tank | jfrederick | Plumbing Inspections | 3 | 11/17/08 3:35 PM |
| Water heater expansion tank | jfrederick | Plumbing Inspections | 0 | 11/17/08 8:18 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
