Ok
Lets get something on the table here Pressure and flow rate Flow rate can be calculated by putting a 1 - 5 bucket under a faucet and timing how long it takes to fill it. No big deal -- Pressure is measured with no flow - which means very little if the feed pipe is very small So when is this an issue? My vote is flow rate -- give a darn about pressure - this takes into account the pressure and possible restrictions And what is a flow rate when we should flag the results. Remember that some ***** might have put in a water saving valve or just reduced the shut down valve under the sink. A little information here would help rlb rlb |
Fuction flow, is normaly at around 4 gpm Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Richard,
Do you check for functional flow with a pail or bucket? Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Thanks Gerry
Yes 5 gal bucket outside faucet only Inside is a judgment call based on the eyeball and comparison to other inside faucets Same with drain speed I will take a picture of a slow faucet if I can for the report rlb |
| Reverse Osmosis | phinsperger | Plumbing Inspections | 3 | 10/30/07 6:28 PM |
| Does anyone know anything about corrugated stainless steel tubing (CSST)? | gromicko | Structural Inspections | 5 | 9/28/07 6:24 PM |
| Pressure question | mtimpani | Plumbing Inspections | 7 | 4/22/07 12:51 PM |
