Gas Line was connect to pressure relief valve. (see Photo)
Anyone help me how do I comment. |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It's a watts 210 valve http://www.watts.com/pages/_products...s.asp?pid=3435 and it shuts off the gas.
The install is sloppy in my opionion. There is to much flex line going on. |
Please advise.. Thank you ! |
The gas supply should be running from the main fuel supply, through the Watts valve, to the WH control valve. The watts Valve is typically used when a TPR valve is impractical for the installation.
The only comments should be;
1) The appliance connectors are longer than allowed for this application. Appliance connectors are restricted to 36" maximum. 2) The use of a Watts 210 Gas Shutoff requires a pressure relief valve on the plumbing system. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
It's wrong even as a Watts 210 installation.
See the diagrams for installation. http://media.wattswater.com/es-210-5.pdf You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
What do you see as the problem Mike - other than the appliance connectors?
It may be there but from the photo you can't tell. Quote:
Gotcha.
The relief valve doesn't necessarily have to be "within site" of the water heater. It simply has to be on the system with no shutoff valve between the tank and the relief valve. Often, in multifamily construction, a dedicated line will be branched off of the hot-water side, and the relief valve will be installed somewhere near the exterior of the structure. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Goulds 1/2 hp, jet pump, discharge pressure | sshockley | Plumbing Inspections | 6 | 6/16/09 9:12 PM |
| air pressure test vs. hydrostatic pressure | mcyr | Plumbing Inspections | 22 | 7/11/06 6:11 PM |
| TRP Drain Line Question | psmothers | Plumbing Inspections | 22 | 7/6/06 4:57 PM |
