I had 90psi coming into the house at the main water valve. The bathroom sinks had very low flow and the tub had such low flow that when you tried the shower, water just dribbled out of the shower head. The valves to the sinks were open all the way.
My question is what types of things can I tell my clients when they ask me "what causes this"? (very high pressure- tons of volume - outside, but hardly any water inside) "Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Jason1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
But remember PRESSURE does NOT equal FLOW. |
The house was vacant but the realtor called the owner, he came out and adjusted the valve, all was fine.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mark what year was the home built. What is the piping material?
To many factors to consider. |
1999 Pex
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
Check to make sure that the valves at the PEX manifold are fully opened.
| Reverse Osmosis | phinsperger | Plumbing Inspections | 3 | 10/30/07 7:28 PM |
| Hydrostatic Pressure Test | Edward D. Wend | Plumbing Inspections | 9 | 6/5/07 4:58 PM |
| Pressure and flow rate | rbennett | Plumbing Inspections | 4 | 10/2/06 9:56 AM |
| air pressure test vs. hydrostatic pressure | mcyr | Plumbing Inspections | 22 | 7/11/06 7:11 PM |
