Old 6/28/09, 8:26 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default Pressure Regulating Valve
Recently inspected a 1920s house that had water service supply lines updated. I noticed 2 PVC "clean-outs" protruding from the ground adjacent to the water meter. In one I found the main cut-off valve for the house. In the second I found the PRV. I usually see the PRV in the house (crawlspace or basement). This house was on a slab but has anyone else found PRVs in the ground? Just a first for me.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Find an InterNACHI certified Delaware Home Inspector (and anywhere else in North America)
Old 6/28/09, 9:24 AM
Michael R. Boyett's Avatar
Default Re: Pressure Regulating Valve
Yes, 99% of them (valve & PRV) around here are near the meter and accessed via a ~6" pvc pipe, usually with a small cast iron cover on them. SOP for SOG
Old 6/28/09, 9:31 AM
That's good to know. I have a client that is going to change over from a well to county water. May be a good setup for them since their house is on a slab.
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 6/28/09, 9:57 AM
The issue that I see here with that arrangement is that over time, maybe 5 years or more, then the pvc gets filled up with dirt and debris and obstructs the access to the valve or the prv. I have a standard comment that says:
The water meter vault and/or shut-off valve access is full of dirt and other debris and should be cleaned to provide quick, easy access in case the water needs to be turned off in an emergency.
Shut off valves required? jcahill Plumbing Inspections 11 9/2/08 1:07 AM
Hydrostatic Pressure Test Edward D. Wend Plumbing Inspections 9 6/5/07 3:58 PM
Water Heater Pressure Valve wrosario Plumbing Inspections 3 7/7/06 7:27 PM
