Old 9/19/08, 11:01 AM
Russel Ray's Avatar
Default Pressure regulators and expansion tanks
If you find a water pressure regulator on the property, do you automatically call for an expansion tank at the water heater if one is not present?
In all the states where I've worked in real estate, I've only found one expansion tank on a water heater, and that was here in San Diego back in 2002 or so.
I recently met a home inspector in Washington who always calls for an expansion tank if one is not present and there is a pressure regulator on the property.
Haven't heard of this requirement before and cannot find such a requirement in any of my books at the moment.
Thanks for the guidance.
I'll also try to check with some plumbers here later today.
Old 9/19/08, 11:36 AM
Bob Elliott's Avatar
Default Re: Pressure regulators and expansion tanks
It is required here, and I call it out .
Old 9/19/08, 11:43 AM
Jeffrey R. Pope's Avatar
The existence of a regulator does not automatically make it a requirement. It's a bit more complicated than that.
608.3 continued. . .
In addition to the required pressure or combination pressure and temperature relief valve, an approved, listed expansion tank or other device designed for intermittent operation for thermal expansion control shall be installed whenever the building supply pressure is greater than the required relief valve pressure setting or when any device is installed that prevents pressure relief through the building supply. The tank or device shall be sized in accordance with the manufacturer’s recommendation.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/19/08, 11:57 AM
Sorry , I am speaking of water heaters in general at install, and not referring to with pressure regulators.
Old 9/19/08, 12:38 PM
kpierce's Avatar
kpierce kpierce is offline
Please Note: kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't call out "requirements". It is, however, a safety concern so I do.
Old 9/19/08, 1:15 PM
I don't agree that it's a safety concern.
If your relief valve setting (whether on the heater or supply) is 150 psi (example) and your street/supply pressure exceeds 150 psi, the expansion tank is just a means to prevent opening of the relief valve when the system is closed - i.e. no water running.
Even with regulators, a closed system can gradually build up pressure equal to supply pressure. Eventually, even with an expansion tank, the relief valve will open if the system remains closed.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/19/08, 1:32 PM
Even with drain pans , we have a lot of high rises , so it depends on your area.
Yes the tpr should be enough in a home , one would think.
Old 9/19/08, 5:12 PM
Bruce M. Graham Bruce M. Graham is online now
They are required with backflow preventers.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 9/19/08, 5:59 PM
Russel Ray's Avatar
Hey, Bruce.
Define a "backflow preventer" in your area for me. Thanks.
Old 9/19/08, 8:53 PM
Russel Ray's Avatar
Hey, Jeff.
What do you think about this: http://www.watts.com/pro/divisions/w...sp#generalinfo
Old 9/19/08, 9:13 PM
I haven't seen you around for a while Russel. I hope life is good for you and yours.
Larry Kage, CMI
231 929 3525
Old 9/19/08, 9:16 PM
Bruce Thompson's Avatar
Bruce Thompson Bruce Thompson is offline
Hey, Bruce.
I'm a different Bruce, but I'll answer...
In my area, it is a double-check valve.
Bruce Thompson
Professional Inspector, Lic. #9199
Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area.
www.TylerHomeInspector.com
NACHI 06081394
Old 9/19/08, 9:28 PM
Brian E. Kelly's Avatar
PEX piping.......................
Old 9/19/08, 9:37 PM
Russel Ray's Avatar
As my wise old grandmother said, "If you get too many negative people ni your organization, find a new organization."
Old 9/19/08, 9:58 PM
RR
from your link differant page
http://www.watts.com/pro/_products.asp?catId=65
where have you been? hope all is well
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Pressure regulators dmacy Plumbing Inspections 1 6/23/08 10:30 PM
