Check out this picture. This water heater has a temperature limiting device that shuts of power to the element so the valve at the top would only need to be a pressure relief valve and a discharge pipe. Obviously there is no discharge pipe but possibly the round part at the top could be a knob for a PRV. I have never seen one like this before. My first thought was that the valve was missing altogether but there was pressure on the system so something is keeping the pressure in. Any of you recognize this?
Thanks. Benchmark Home Inspection Services. http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas. |
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Never seen anything like it. Appears to be plugged. No matter what, its not right and needs repaired/replacement as deemed necessary by a licensed plumber. What is in the background is that mold on wall?
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Yes, it definitely needs work. Not a huge issue because it is a rental but I was curious about this type of valve.
That is not mould on the wall. It is a stone foundation. What you are seeing is the different colour stones and the mortar. Benchmark Home Inspection Services. http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas. |
LOL....just looked weird in the picture.
The hex on top is the pressure relief adjustment. This is a very old pressure only relief valve. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Michael is correct.
I used to see a lot of those adjustable relief valves years ago. It probably wouldn't work if needed now. |
| Tankless water heater issue | sstanczyk | Plumbing Inspections | 18 | 12/2/10 6:15 PM |
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
