Any idea on why this would be installed on public supply? I'm assuming that this is a pressure tank and pump. Line on the bottom is the supply, top line goes out to the house lines.The property has a pool and sprinkler system but it didn't seem to be connected to these. I tested the pressure on an outside bib and it was 52 psi. Ran water throughout the inspection and this did not run at all. Any thoughts? The gauge read 42 psi.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
| Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Some municipal water systems at the end of the line have less than 40 psi. Looks like this homeowner came up with his own solution.
Booster pump
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
| hydronic radiant floor heat on hot water tanks | mnicholet | Plumbing Inspections | 7 | 4/14/10 5:48 PM |
| Site grading and drainage | wdevries | Canadian Inspectors | 5 | 10/6/09 10:23 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
