Does anyone pressurize water lines with compressed air when the water is off ?
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What would be the purpose? The short answer is NO. If there was a leak, how would you find it in all the hundreds or thousands of feet of supply lines, many of which are buried in the walls, crawl spaces and attics. You would not be able to see anything but perhaps a drop in pressure assuming you had a good gauge and system for installing it. Would take a lot of time and effort for little or no return in information.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Another short answer is, they don't know what in the hell they are talking about. I realize you can't just blurt that out to them, it tends to offend some people. Go figure.
I tell them a pressure could take hours, it will not locate the leak and it would be cheaper to have the water turned on.
Bill Emelander Professional Edge Home Inspection Grand Rapids and all of West Michigan NACHI #03111914 www.proedgehi.com |
http://captsized.inspectorpages2.com
Home Inspections RI Rhode Island 401-782-5589 Yes, I have many times. Plumbing fitting with gauge attaches to outside 3/4 hose bib. Do not over pressurized system. If no leaks it will hold pressure, 15 minutes is all you need at 7 to 15 psi. Test drain traps with jug water. |
| Water Tank Lines | dlee2 | General Inspection Discussion | 3 | 7/23/09 10:57 PM |
| Hot water heater question | mgeddie | General Inspection Discussion | 15 | 6/7/06 1:00 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
