Old 8/16/06, 2:02 PM
jburk2's Avatar
jburk2 jburk2 is offline
Default Private plumbing main shutoff location
Hey guys, I thought I might pick the collective brain of NACHI and draw from the well of everybody's expansive knowledge (is that enough arse kissing? )
I don't get the chance to inspect too many private water supply systems and ran into what I believe to be an issue. Correct me if I'm wrong, but the main water supply shutoff should be located between the entry piping and the pressure tank right? I advised the client that this is not the accepted practice and that a shutoff should be installed in said location.
As it stands, the only shutoffs were located post entry piping/pressure tank.
It's fun being me. Is it fun being you?
-Denny Crane
JB Home Inspection Services, LLC
Grand Rapids, MI.
www.jbhomeinspections.com
Old 8/16/06, 2:10 PM
jburk2's Avatar
Default Re: Private plumbing main shutoff location
I don't think the pictures went through. Let's try this again.
private-plumbing-main-shutoff-location-inspection-photos-08-14-2006-040.jpg   private-plumbing-main-shutoff-location-inspection-photos-08-14-2006-084.jpg
-Denny Crane
Grand Rapids, MI.
Old 8/16/06, 7:59 PM
I see them like that all the time, Jerry...not a problem.
If you want to drain the pressure tank, shut the well breaker off, close the shut off valve to the rest of the house and open draincock.
Look here: http://www.do-it-yourself-pumps.com/...itting-kit.htm
Old 8/16/06, 10:56 PM
Mike Parks's Avatar
Mike Parks Mike Parks is offline
Please Note: Mike Parks is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jerry
After the tank. No problem.
Before the tank IS a problem.
The pump might never shut off.
Old 8/16/06, 11:02 PM
Paul Pendley Paul Pendley is offline
Post shut off is correct. Not that it would really help but the holding tank is supposed to also be the initial water supply for fire fighting. I got this info from the city fire marshall. If someone knows different let me know. Like I said its not much to fight a fire but its a start.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 8/17/06, 8:17 PM
Mike Parks's Avatar
I should have looked at the picture before posting.
It is installed correctly.
Old 8/18/06, 8:31 AM
jburk2's Avatar
Thanks guys.
I was initially thrown off by one of my AHIT inspection books, which I referenced on scene, stating that the shutoff should be located between the tank and the entry piping. I suppose I will call the client to let him know that the instalation is correct, ammend the report, and send him a revised copy.
Kind of embarassing
-Denny Crane
Grand Rapids, MI.
Old 8/18/06, 1:15 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
If I were to rough this in I would have put a valve on the main line about a foot from the wall. It would make replacing the pressure tank much easier since you would have to disconnect all the piping going into the pressure tank to do so since there is not a union on the pipe going to the pressure tank.
Old 8/18/06, 8:30 PM
Mike Parks's Avatar
Jerry
All mistakes embarrass us. The fact that you admit it will make you more credible.
Old 8/19/06, 4:23 PM
jburk2's Avatar
Originally Posted by Mike Parks
Jerry
I hope this is the case. I will call the client on Monday morning and explain the situation. I'm hoping that he will appreciate the effort I put into researching this situation and overlook the mistake
I might call AHIT and tell them that their book is wrong though
-Denny Crane
Grand Rapids, MI.
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
Main Panel location dmacy Electrical Inspections 5 12/6/06 6:32 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
