Old 11/8/07, 9:08 AM
mashburn's Avatar
mashburn mashburn is offline
Default Proper Connection?
I got to my inspection yesterday and a local plumber (certified) was there installing a new water heater. When I finished upstairs and came to the basement, after he was gone, I found this.
Ashburn Inspections
724-516-1665
Old 11/8/07, 10:45 AM
David P. Valley's Avatar
Default Re: Proper Connection?
Appears to be on both sides.
Doesn't appear to be a Dielectric Union? Most water heaters have copper at this connection.
Old 11/8/07, 10:56 AM
Michael Larson's Avatar
Is that really a galvanized nipple to black iron coupling to copper pipe to sweat adaptor. Sheesh!
Old 11/8/07, 12:57 PM
donquique donquique is offline
Please Note: donquique is a non-member guest and is in no way affiliated with InterNACHI or its members.
I do not think so. If these materials have different dielectric properties corrosion will result.
Old 11/8/07, 2:46 PM
mashburn's Avatar
Yes, quite the connection made I must say. Like I said, he was a certified (in PA) plumber!!
Ashburn Inspections
724-516-1665
Old 11/8/07, 2:49 PM
Must be making future work for himself. Was his business info nearby?
Old 11/8/07, 3:23 PM
Charley L. Bottger's Avatar
Cum'on Mike that is all he had in his truck what do you want perfection we would be out of business if not for guys like that.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/8/07, 3:50 PM
Bob Elliott's Avatar
What? ...you guy's haven't seen the new black copper couplings yet?
Old 11/8/07, 4:46 PM
Well, he could have painted it all with some of that copper-looking stuff !!
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 11/8/07, 7:28 PM
mashburn's Avatar
He had the big truck with him. His business is about 20 minutes away. He did however remove the former heater and load it onto the truck. Most impressive.
Ashburn Inspections
724-516-1665
Electricians Check List pabernathy Electrical Inspections 74 12/5/07 6:39 PM
Grounding rod connection from meter box fbartlo Electrical Inspections 37 7/28/07 12:30 PM
Is this connection correct? mpeterson Electrical Inspections 10 3/27/06 10:45 PM
Proper distance between a washer drain pipe and 220 volt dryer connection rpaul Electrical Inspections 14 1/3/06 9:43 PM
