Old 1/23/07, 10:05 AM
waksell waksell is offline
Default Public or Private
What other ways are there to determine public or private sewage system?
Only way I know of is if there are manhole covers in the street.
A possible clue might be a mound in the yard, but not positive.
Old 1/23/07, 10:12 AM
arook arook is offline
Please Note: arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Public or Private
The water meter is a good indication of public water.
Old 1/23/07, 10:20 AM
Thats true, didn't think about that.
Old 1/23/07, 10:52 AM
dbush's Avatar
dbush dbush is offline
Send a message via MSN to dbush Send a message via Yahoo to dbush
Please Note: dbush is a non-member guest and is in no way affiliated with InterNACHI or its members.
Water meter is a good indication of public water, but not necessarily private sewage. A cleanout is ALMOST always required for Septic Systems.
Old 1/23/07, 12:09 PM
dgagneur's Avatar
dgagneur dgagneur is offline
Please Note: dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good point Dave,
I just did an inspection to include well and septic...there was a well but I couldn't find the septic anywhere so i flushed a locator and away it went, down the city sewer.
Surprising thing is that the seller said the house was on a septic system. Oh well, lesson learned there.
Dave
Old 1/23/07, 12:50 PM
David. What is a locator?
Old 1/23/07, 2:39 PM
dgagneur's Avatar
It's a device that helps you locate hard to find septic tanks. Basically you turn the device on and flush it down the toilet. Then walk the yard with the receiver until you pickup the beacon. If all goes well, you find the tank and are able to retreive the device for future use. It works well as long as your not on city sewer...if you are, then not so well. Each device runs about $20-$25 so you hate to see them disappear.
Dave
Old 1/23/07, 2:54 PM
wsiegel wsiegel is offline
Wes,
All of my reports indicate that I do not now if the home is on a sewer or septic system. The only way to know for sure is (i guess with a locator - didnt know about that one) to have a plumber come and snake out the line. They measure the distance of the snake and that tells them where the line goes to. Another good way to know is to as a neighbor, if they have lived there for any lenght of time (neighbors are a great source of information).
There are many areas down here that were on spetic tanks at one time. Once the city installes sewer lines those homes show up as being on city sewer. The questions then becomes, did the homeowner pay and have his home hooked up (a lot of municipatilities require the homeowner to hook up).
I had an inspector friend who always listed the system as unknown. A realtor he was working for came back to him and tried to get him to commit to sewer or septic. The mls and city taxroll showed this home to be on sewer. Turns out the people never hooked up, the tank was under the sidewalk. The side kick to this the clients told the agent they absolutely did not want a home on a septic tank. This realtor tried to make the inspector commit so she could hang him out to dry. As it turned out, the realtor had to shell out almost $6000.00 for the client.
Ever since that story my reports say unknown.
Old 1/23/07, 3:31 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dave
Why would you want them to reappear?
Eeewww.
Rinse and go, i guess.
cool though.
Old 1/23/07, 3:56 PM
Roy D. Cooke, Sr's Avatar
Usually but not always the septic is in the back yard .
Find the Sanitary access usually 1/2 way up the wall for septic ( sometimes city sanitary is also up there to ) . Now go out from the access and about ten feet is where they normally have the tank in my area.
Look close has the ground not level with the rest of the area or has it been dug up recently .
(Usually the town sanitary is below the basement and goes out the front of the home .)
This is the usual access hole or two for having the tank pumped out .
Take a 7/16 rod A BBQ Rotisserie shaft works well ,Push this into the ground you can sometimes find the tank ( I also use this to find buried Oil tanks 7 so far ).
As some one said ask the neighbors .
I love neighbors they just love to tell all about the home and when things have been done.
Incidentally septic additives do not help the system and are not needed .
Some times can damage the system
Roy Cooke
Good one William thanks
Old 1/23/07, 4:13 PM
jking2 jking2 is offline
Yes. Opening a septic tank and digging around inside is a tough way to get $25.00 back.
Old 1/23/07, 4:41 PM
Sounds like risky business, if you make a mistake about public or private. I think I will penn a disclaimer.
As for the locator, I would just have to wright it off as a cost of doing business, too stinky.
Old 1/23/07, 5:21 PM
ldapkus ldapkus is offline
We have a private well and private septic. The city installed public sewer several years ago, but we did not tie into it since our septic was working fine. The hookup would cost $2000 and sewer fees are approximately 30 five dollars a month, so we did not hook up to the city system since our sewer works fine.
Old 1/23/07, 5:51 PM
What are your thoughts on this:
By visual inspection only, I believe this home to be on a Public / Private sewer system.
Disclaimer
The determination of whether a home is on a public or a private sewer system is not always possible by a visual, non-invasive inspection.
One clue would be manhole covers in the street, this may indicate the presents of a public sewer system. There is no guarantee that this home is connected to it. A sewer system may have been installed in the street after this home was built, and connection to it may not have been mandatory.
A cleanout in the drain/waste pipe may indicate a private system. There may have been a private system in use at one time, but has since been bypassed and connected to a public system.
One possible way to tell if a septic tank is present is to poke a rod into the ground in the area where a tank might be. You may hit something solid, and it may be a tank. It might not be a tank. If it is a septic tank, is it still being used? Or has it been bypassed and now connected to the public sewer? Drain field pipes that come out of septic tanks are usually plastic. Poking holes in them will allow dirt to enter the pipes and damage the drain field.
The truth is that there is no definite way to tell visually. Recommend that Client ask the seller if this home is on a public sewer system or a private system. If seller cannot answer the question, recommend having evaluated by a Licensed Plumber. If a private system, ask seller when was the last time it was serviced. If last service date is undetermined, or more than a couple of years, recommend servicing.
Old 1/23/07, 6:14 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Wes:
Seem kind of wordy-- --lol.........
This goes into all of my reports;
The waste disposal system appears to be connected to a public sewer system. There are isolated instances where the system has not been connected to the public sewer system but remains an on-site system. Client may wish to confirm sewer connection with the local building department or the property owner prior to close.
Hope this helps
Cheers
</IMG>
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Florida Licensing Bill - Action Soon jburkeson1 Legislation, Licensing & Legal Issues for Inspectors 250 7/1/10 4:50 PM
Public or Private? belliott General Inspection Discussion 10 4/26/07 9:24 PM
Misuse of Title rwand1 Canadian Inspectors 40 10/15/06 8:29 AM
