Old 11/12/09, 1:53 PM
David C. Macy's Avatar
Default Pump at water heater drain valve and timer controlled device.
Pump was off at panel. Appeared to be for 3rd floor baseboard heating.
The home had forced warm air 22 years old. Finished attic had the baseboard registers supplied by this pump.
Any comments on the pump.
Also there was a electrical timer that was also feed off the water system. Any ideas what it was for? Going back for a radon pickup and will in quire with owner.
ID:	33216   pump-water-heater-drain-valve-and-timer-controlled-device-150609-064-small-.jpg.jpg
ID:	33217   pump-water-heater-drain-valve-and-timer-controlled-device-150609-052-small-.jpg.jpg
Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America)
Old 11/12/09, 1:59 PM
Jeffrey R. Jonas's Avatar
Default Re: Pump at water heater drain valve and timer controlled device.
Creative method of replacing/upgrading the boiler 22 years ago, without having to duct (or 2nd unit) the finished attic?
Old 11/12/09, 2:13 PM
By the looks of the register and stain I would say that my be why the breaker was off.
Timer connected to water heater? dnasser Plumbing Inspections 34 8/13/09 5:11 PM
Mixing valve? mboyett Plumbing Inspections 12 8/14/08 11:37 PM
H2O Heater automatic pump..??!! tyeager Plumbing Inspections 10 8/26/07 11:52 AM
