Old 8/31/08, 2:34 PM
Al D. Bolt Al D. Bolt is offline
Default Pvc
Can anyone tell me why PVC should not be used as hot & cold water distribution piping?
Thanks.
Old 8/31/08, 2:51 PM
Stephen W. Stanczyk's Avatar
Default Re: Pvc
It does not hold up to the constant pressure and heat of a distribution system. If you want to use a similar product, use CPVC that is approved for this application.
Stephen Stanczyk
Old 8/31/08, 5:04 PM
Jeffrey R. Pope's Avatar
Default Re: Pvc
Cuz the codes say so. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/31/08, 6:14 PM
Default Re: Pvc
Thanks.
This may help explain a little.
http://www.harvel.com/tech-specs-pvc-pipe-40.asp
Corrosion resistant pressure pipe, IPS sizes 1/8” through 24”, for use at temperatures up to and including 140 °F.
Also refer to IRC:
P2904.5
Hope this helps.
Marcel
