The other day I saw a first (for me). The home had been a rehab (sort of). The guy replaced all the plumbing. For the hot water he used CPVC which was fine. But for the cold he used PVC. I didn't make an issue out of it, but what is the official word on PVC being used for the cold water supply?
For what its worth, this is what I put in the report... 1.Observed the cold water pipes in the home are plumbed with PVC piping. In most cases, CPVC is used on all clean water pipes, and PVC is reserved for waste pipes. While this will likely not cause any serious concerns as this is only used on the cold water side, any future plumbing work should be done in consideration of this. It would be very easy for someone to accidentally connect a waste pipe to this supply piping in ignorance. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America) |
I would say probably 90% of the homes here have PVC for their main supply line coming in off the meter / street. I see PVC for cold water supply a lot particularly in rehabs. It is cheap, easy to install and will last virtually forever as long as it isn't exposed to UV. Same for sprinklers and Pool equipment; pumps, filters, etc. ALL PVC.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I found this...
http://www.ppfahome.org/pvc/index.html |
PVC is not allowed for interior distribution.
Is there a reason for that?
Other than the "codes don't allow it?" I'm not sure. . .
This might help;
http://www.nsf.org/consumer/plumbing/index.asp PVC, CPVC, PEX, and Other Plastic Plumbing Materials Plastic plumbing has been used for potable and non-potable water applications since the 1950s. Initially, there were many concerns about these products potentially leaching harmful chemicals into the water. To ensure that the public's health was protected, independent standards were quickly developed which established strict guidelines for these products. Today, plastic plumbing products designed for potable water applications are usually designated with either "NSF-PW" or "NSF-61" to indicate that the product complies with the health effects requirements of NSF/ANSI Standard 61 for materials designed for contact with potable water. \ This standard also establishes similar guidelines for other plumbing materials, including copper tubing. If your pipe is not coded with one of these designations or if it is designated with an alternative code such "NSF-DWV," it is probably not meant for potable water applications and should not be used for such purposes. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
OK per IL plumbing code...
http://www.ilga.gov/commission/jcar/...ZZ9996aaR.html About 1/3 of the way down . |
It's always advisable to check your local codes. . .
Someone should tell People here they are not allowed to use PVC here . It is every where
Copper supply is the norm here.
Bill Boerner STL Home Inspection ServicesServing St. Louis/Surrounding (314) 805-2137 billy.boerner@gmail.com http://www.stlhomeinspector.com |
| Refrigerator Water Dispenser Works Only Intermittently | Matt Ablemarle | Plumbing Inspections | 2 | 6/9/08 5:49 PM |
| Hot water first then cold out of cold side of fixture | jberthiaume | Plumbing Inspections | 19 | 3/12/08 2:32 AM |
| smelly well water | afrost | Ancillary Inspection Services & Additional Topics | 22 | 11/21/07 8:30 PM |
| More water, different windows | Brenda | Exterior Inspections | 12 | 9/22/06 3:55 AM |
