The plumber used cpvc glue on the drain pipe. Would you write this up? Is this a bad install? I know the answer because I called oatey who made the glue (they left a bottle for evidence). Opinions anyone.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net Last edited by sfogarty; 7/8/11 at 7:24 AM.. |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Answer: Do you want to explain why you noticed it and didn't write it up when these people go to sell and Wayne inspects it and throws you under a bus.
I would mention it and leave it them if its "important" or not. Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
NO... not anymore. You spoiled it for us!
Cpvc is designed to withstand higher temps, and chemical applications, there would not be an adverse affect in using cpvc glue on pvc piping.
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
They sell sunglasses too!!
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
There I fixed my type o. Chris can poke fun but he never posted an answer.
John was correct. If it would have been the opposite,pvc glue on cpvc, it would needed to have been cut out. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
There really should not be a need to install cpvc pipe in a residential house Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
Absolutely.
Why do you feel that way? I see it often, in new and used residential houses and apartment buildings.
I will retract my former statement. If you feel the need to have hot water in excess of 140 F then you may want to use CPVC that will cover you up around 200 F Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
P2905.5 Water-distribution pipe. Water-distribution piping within dwelling units shall conform to NSF 61 and shall conform to one of the standards listed in Table P2905.5. All hot-water-distribution pipe and tubing shall have a minimum pressure rating of 100 psi at 180°F (689 kPa at 82°C). Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| PVC glue on CPVC | bokeefe | Plumbing Inspections | 5 | 12/1/10 10:42 PM |
| Limitation of Liability is Legally Acceptable....(except in Kansas) | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 7 | 9/1/08 11:39 AM |
| Pins and glue aren't enough to support the floor | kshepard | Structural Inspections | 3 | 8/11/07 8:28 PM |
| Blue pvc glue | kgerhauser | Plumbing Inspections | 10 | 1/26/07 3:47 PM |
