Old 9/25/06, 4:55 PM
Rick Koehler Rick Koehler is offline
Unhappy PVC piping
I found white PVC tubing used as the main water supply line from the well. The only markings found are as follows: American PVC 1120 BP-2, SCH40 ASTM d-1785 370 PSI 73 degree F ASTM D-2665. Does any body know if this is correct tubing to use?
Regards
Old 9/25/06, 5:21 PM
away away is offline
Default Re: PVC piping
Richard,
That PVC is fine for the main water supply.
Andrew Way
Keystone Residential Inspection Services PLLC
www.keystoneinspections.com
Old 9/25/06, 6:48 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
This really depends on your area and plumbing code. It was not legal to use where I plumbed (UPC). I would be more comfortable using a schedule 80 rather than 40 but personally would not use either one. PVC does not handle temperature fluctuations well. It will expand and contract quit a bit.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Bonding both hot and hold supply pipes kshepard Plumbing Inspections 22 5/4/08 8:00 AM
Bonding Piping 101....Good To Know ! pabernathy Electrical Inspections 37 4/28/07 11:25 AM
plastic piping? Scott Schultz Plumbing Inspections 5 3/28/07 1:40 AM
