Cut-off is located in the garage....
Piping looks good with no leaks......Is the pvc cap acceptable? ![]()
An Ounce of prevention is better than a pound of cure :} |
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Generally speaking, yes. However, this looks like the position where the pressure relief valve should have been located. Was there a PRV elsewhere on the system?
Not sure if I would call it out, but here's the c*de.
2009 IRC P2904.17.2 Plastic pipe or tubing to other piping material. Joints between different types of plastic pipe or between plastic pipe and other piping material shall be made with an approved adapter fitting. Commentary: The joining of different types of plastic pipe, and of plastic pipe to other piping materials, requires the use of adapter fittings specifically designed for such connections. The adaptor fitting must be compatible with the two dissimilar materials being joined. Adapter fittings must be evaluated individually and approved by the code official. Some key items to review when evaluating adaptor fittings are joint tightness, compatibility of the adaptor with the dissimilar materials being joined, and the presence of any ledges, shoulders or reductions that could retard or obstruct the flow of water in the piping. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
The CPC is similar to the IRC on this matter, however, I don't believe this qualifies as a "joint" or "union."
CPC 316.2.3 Plastic Pipe to Other Materials. When connecting plastic pipe to other types of piping, only approved types of fittings and adapters designed for the specific transition intended shall be used.
whatever it is, it looks torn up and would need to be replaced anyway.
Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
About 8" down from the plastic cap.
Chad Norlen SEI Inspections InterNACHI Member Certified Professional Inspector HVAC Journeyman - State of Idaho EPA Certified Universal Technician |
I see a pressure regulator, not a pressure-relief valve.
Touche - brain fart.
Thanks everybody for the feedback
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Light Switch Near Shower | vsantos | Electrical Inspections | 204 | 3/19/12 9:58 AM |
| Total galvanic reaction? | jtribuzio | Plumbing Inspections | 19 | 4/3/10 2:18 AM |
| copper bar | Unregistered | AskNACHI.org Inspection Questions Forum | 14 | 6/28/09 10:10 PM |
