This is from todays inspection. The vent is only terminating out of the roof, 7". We live in Ohio and the snow that we can get here might just seal the pipe off.
I looked up on the IRC book, section P3103, And they do not give exact lengths? It must be based on regions.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
I believe it's 6" plus anticipated snow depth.
If I had that sewer stack here, I'd simply recommend an extension.
Not really a big deal though as snow will simply fall inside. Unless of course they get ice damming issues. |
David
Thats what I am going to do. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
you did recommend replacement as the collar is starting the crack?
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 2:23 AM |
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 4 | 10/12/07 6:38 PM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 10:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
