Can PVC pipe be used for the main water line entering to the water tank from the pump. Also why would they put an open trap off the waist line.I feel they need to put a cap on the open line to stop gas discharge.
Bruce MacInnes
Noblesville,IN 317-513-1727 www.macinnesinspection.com |
Robert,
The PVC is fine for water supply material. What is that black crap at the fitting? Was this fitted properly at the elbow? I'm wondering why they used two different materials when all they had to do was make a simple PVC connection. As for the trap, it needs to be permanently sealed if there's nothing draining into it or if there's no trap primer. |
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are you sure that's not a sleeve containing the true water line and the pump wires? It looks like those wires might be going into the larger pipe making me think it's a sleeve.
Me too. That trap looks like someone wanted to add something in the future and it never got done.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
The conductors look individual and not sheathed.
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Leak in water line outside ... what is ... | Bill Featherstone | Plumbing Inspections | 6 | 1/12/08 8:17 PM |
