Old 9/7/11, 11:51 AM
Brad Hern Brad Hern is offline
Please Note: Brad Hern is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Question: Bathroom sink drain/p-trap
Hey there,
I'm not really great at fixing plumbing issues but am attempting to fix an upstairs p-trap. The problem is this; The main drain comes down and the p-trap connects to it...the problem being that the other end of the p-trap is not matching up with the pipe that goes into the wall. It's a good 1/2" off.
Any advice? Thanks.
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/7/11, 5:23 PM
Kenneth R. Brittain Kenneth R. Brittain is offline
Default Re: Question: Bathroom sink drain/p-trap
Brad which way is it off? Is the p-trap tail piece which goes into the wall pipe too high or too low?
Old 9/7/11, 5:27 PM
Christopher Currins's Avatar
Length or diameter?
Christopher Currins
Certified, Licensed
Old 9/7/11, 5:45 PM
I'm sorry. It's off on the "horizontal plane", not vertical.
Old 9/7/11, 7:09 PM
If its the right height and length then you should beable to loosen the couplings and skew the trap to the right or left so it fits. Start by putting the tail piece or arm into the pipe that comes out of the wall, it may seem too long but for now thats ok. then move the trap until it lines up with the part of the arm that is pointing down. If the arm is too long cut some off the other end. Hope this helps and make sense.
Old 9/8/11, 5:47 PM
Thanks, it does.
Trap question dmacy Plumbing Inspections 22 6/27/07 7:17 PM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
Sink Clog dirtydishes Plumbing Inspections 26 8/27/06 3:48 PM
Quick and easy trap question Danny Castellano Plumbing Inspections 4 8/14/06 12:17 PM
