Old 7/6/10, 5:11 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Question - Clothes dryer transition ducts
Clothes dryer transition ducts should be metal, should not be concealed within construction, and they should be limited to a single length not more than _____ feet.
What's your answer? (try to refrain from looking it up )
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/6/10, 5:15 PM
Tom Leahy Tom Leahy is offline
Default Re: Question - Clothes dryer transition ducts
Seems I remember 8ft?
Fort Worth Home Inspector
Dallas Home Inspector
Old 7/6/10, 6:09 PM
mnahrgang's Avatar
I was thinking 6...
Mark Nahrgang
www.HeyMark.info
Old 7/6/10, 6:19 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
8 feet
Old 7/6/10, 6:25 PM
Jeffrey R. Jonas's Avatar
6 ft.
Old 7/6/10, 8:00 PM
Larry J. Michael Larry J. Michael is offline
6 Feet
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Old 7/6/10, 8:12 PM
I am revising my answer...
8 feet for IRC
6 feet for UMC
It depends on where you live and what code they are enforcing.
Old 7/6/10, 8:21 PM
Although sold in 8' lengths, needs to be installed per the Manufacturers installation requirements and listed for that installation.
Even better, install one of these and elliminated the lint collector venting.
Old 7/6/10, 8:26 PM
Here is an actual installation.
Old 7/6/10, 9:42 PM
Marcel,
I'm not quite sure I understand what your showing here.
That looks like a box, inside the wall, inside which the end of a smooth-metal dryer duct is extended, ready to connect to a flexible duct to the dryer. Yes?
BEN GROMICKO
Old 7/6/10, 10:21 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Many vents are further than 8'. Depends on the age of the dwelling and the location of the utility room, which in many instances, was rougly dead center.
You can have a 28' deep raised ranch, with the dryer installed in a utility room, on the ground floor in the center of the dwelling. Distance to exterior wall may be 10 feet as a horizontal run, with a vertical run of 8' and two 90 degree elbows.
I see it every day and simply state that the configuration is potentially problematic and may not meet current code requirements. Additionally I state that there are more dryer fires annually than chimney fires, and thay should have the dryer vent cleaned twice a year.
If I spend more than two minutes looking and evaluating the existing condition, I am spending too much time on it, IMO.
Old 7/6/10, 11:11 PM
8 feet for IRC
6 feet for UMC
Transition ducts...Scott's got it.
Larry Kage, CMI
231 929 3525
Old 7/7/10, 5:32 AM
Originally Posted by bgromicko View Post
Marcel,
That's what it is Ben, a Dryer box that only needs 2' of flex duct and the dryer can be pushed close to the wall without kinking or crushing the duct as we see too often. Smooth duct from that point on.
Old 7/7/10, 4:18 PM
Eragorn Northe Eragorn Northe is offline
the flexible style dryer connection adds 10 feet, in the distance
the straight metal is 6 ft, i think
Eragorn Northe
Der Hous Inspector LLC
cell-306-684-1748
www.derhouseinspections.com
Old 7/7/10, 4:49 PM
Transition ducting is not calculated into the length of the dryer vent to determine the maximum length. I don't know where you were going with the straight metal comment though.
Got a letter from ASHI's President today. gromicko General Inspection Discussion 55 12/12/10 11:51 PM
Dryer Vent Repair Philadelphia nhagarty Ancillary Inspection Services & Additional Topics 0 1/12/09 9:22 PM
