This is for my home.
I am adding a half bath in a bump out. I would like to avoid a VTR in the bump out as it is near some upper windows. The new toilet will be be physically in line with the old with a sink upstream from there. Venting ideas? TIA, Tim |
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is there any reason you can't put a vent line above and behind the added sink location that ties in top the existing vent?
I wondered where my pool vac hose went!!!
Rich Mangold RCM Home Inspections, LLC www.RCMHomeInspections.com Email: Rich@RCMHomeInspections.com Phone: 847-698-5993 |
Jeff, Is that your attic?
Mike, the way the bump out will be attaching to the house, it would be very difficult to get the sink vent over to the existing vent. Especially since the main stack is encased in 6" of sprayed icynene. I may just have to add another stack - as far from the windows as I can get it. But it would be nice to avoid it.
Tim, does your state allow AAVs?
You could have an AAV at the sink if the new toilet is within the allowed distance(varies by jurisdiction) to the vertical stack. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
If it's legal in the IPC, it's legal here. I've thought about the AAV. It's in my bag of options. The new toilet might just make the 6' distance to the vent.
Tim |
If you get desperate...http://www.toiletvent.com/productinfo.htm
Perfect, Bob. Thanks.
Tim |
Huh?
Did you mean venting or gaseous emissions control You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Seems to me that it would be inefficient due to leakage as there is no a s s gasket included.
I am wondering if this is real myself.
Power cord may be low voltage ,which makes through wall acceptable. Think Doorbell and phone. |
I would add a studor vent in the wall between in the wall between the two bathrooms located behind a access panel.
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
| save a plumbers job | John C. Morgan | Plumbing Inspections | 6 | 2/9/07 12:07 AM |
| Slab leak question | rray | Plumbing Inspections | 4 | 12/25/06 10:52 AM |
