Hello Everyone
How do I find out what the water PSI? Isnt there suppost to be a gauge, on a water heater that tells you that?Thanks for your time and answers Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com |
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Before your next inspection you need to make a trip to Home Depot or Lowes and get a gauge. I usually just check the pressure at the hose bib.
If the house has a well, typically, there will be a gauge near the pressure tank.
dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
If the shower makes it to the end of the tub its fine.
Is that a 5 or 6 foot tub?
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
When testing the pressure of a system supplied by a well, do you check the pressure with and without the pump running?
Frank P. Newman Emerald City Inspections, LLC Dublin, GA Last edited by fnewman; 7/22/08 at 9:28 PM.. |
Not my thread, as in Chicago the pressure is provided by the city,so I am really just testing for flow.
Sounds like a joke ,but to the end of the tub is a test I have been using for 30 years. |
| Two Quick Questions On Receptacles | rtrain | Electrical Inspections | 7 | 11/28/07 12:24 AM |
| Thanks for the quick response | cpatzman | Miscellaneous Discussion for Inspectors | 6 | 6/11/06 11:54 PM |
| Quick Answer Needed - Reward | wdecker | Interior Inspections | 10 | 2/27/06 9:58 AM |
